Mine acts the same way.
I think they all do..very lazy t-stat.
Sure wish it was more sensitive to temp change.
I concur..there is a fine line there.I took the cover off like you suggested and observed the same behavior. Very little movement at any given setting when the stove starts to cool. It would be nice to have it open up more towards the end of the burn, but I'm guessing it can't be much more sensitive or it would start chasing its tail and over correct.
Tell us about your home claybe. I don't think anyone has asked. We love BKs but if your basement is bare concrete and 3000 SF of coldness then no insert can do this job. All we know is that you have a really huge chimney in Colorado which tells us that you have three stories or a steep pitch roof.
I think if it were in the primary living area I would burn less wood and it would more than heat the space.
That would be my suggestion too but its going to cost, Im thinking of doing the same as my princess is in the finished basement and Im going to put a stove in the upstairs FP for the colder weather, havent decided on what to get as me and the wife go back and forth on stoves.Just a thought-
If you decide the Princess doesn't do the job, leave it in place and save yourself the grief of moving it. You'll then be able to load it up and and turn it down lower, keeping the basement in the upper 60's. Now..
Since you mentioned swapping locations and getting a pellet or tube stove, I myself, would find a nice tube stove for the main level instead. You'll be able to enjoy the active fire and re-loads would be easier. Dial the Princess in to load once a day, and have the other stove take on the main heating chore.
In the shoulder season, you'll probably just run the Princess at that point.
someone else said that but the mother could have been the Ridgeback, although that brings up another funny imageYou guys are lucky to have two stoves. If I had a second it would be a non-cat with a big window to get my fire watching itches scratched.
weatherguy: your signature list a huge dog mixed with a toy breed. Had to be comical and/ora tough birth for the terrier. I have a pug, about the same size as the boston.
Not sure if its OK to post here as a NON BK owner but,One of my friends tried heating his house from an unfinished basement and had the same problems, he ended up insulating his basement walls with the foam panels and got a bigger stove and now hes heating his house no problem, the stove being bigger helped Im sure but I think insulating his walls were a bigger help.
All input is good, as far as I'm concerned.Not sure if its OK to post here as a NON BK owner but,
You guys may end up convincing me to try one of these BK stoves.
Id like to be able to dial the heat back more as anything over 30 Deg outside, it gets too hot.
I dont want to insulate my basement walls as the basement gets too hot already.Right now my basement has Zero insulation. Even with the stove on the lowest air setting Stays about 80-84. Perhaps a cat stove would allow for lower heat output over a longer time frame,but i do get long burn times. Every situation is different though.
