1000 Gallon Propane Tanks stacked storage
Or you over fill the boiler and it idles for too long.......you're out of here. Isn't that when webbie takes our hearth pass away?
No, but the annual membership fee is doubled.
Reactions: flyingcow
Has anyone stacked 1000 gallon tanks for pressurized storage?
CJ
Posted a thread on my stacked tanks once before. Got good advice form forum member. I was all hung up in the stratification, verticle vrs. horizontal efficiencies discussed at length on this site on this site. Went with 2 (500 gal) stacked . Put 3 ( 10") pipe ports in center, spaced about 4" in between so as to fit my one poiece system into my building.. I think the bigger the ports the more even the flow. It really made the tanks rigid. My Frohling 50 had a plug in port for tank temps . I put 4 evenly spaced digital gauges to see how it stratified. It works naturally and charges to 180 top to bottom evenly, usually on one charge of wood. I put it on 4 small dollywheels that will handle the load. Moved it with 100 hp tractor with a 2700 lb loader lift on rough terrain and got it to a slab where we were able to roll it into a 82" standard door opening. Quite a ride indeed. It was all the tractor could handle and certainly out of my comfort zone. The 2 stacked 1000 gallon tanks would need serious equipment to move on out of level terrain.
tmudd
