Ran out of wood storage again, time to build another woodshed. Here are links to my previous one, which I built using peeled balsam fir poles from my property and sided with hemlock and maple that I milled:
https://www.hearth.com/talk/threads/timber-frame-woodshed.52493
https://www.hearth.com/talk/threads/wood-shed-update-now-with-siding-also-some-milling-pics.70211
I didn't feel like dealing with balsam this time, and unfortunately our beeches are starting to die from beech bark disease. So I figured I'd use the beech before it's all punky.
First, need to cut some trees down:
This tree was dead, but the trunk was in perfectly good shape. Same with another I felled. Many others are not in such good shape.
Next, I milled some posts:
I got to try out my new Timberjig mill for this. I mostly think it's great for this sort of thing, except that the quality control on one particular part makes square cuts difficult. But that's for another post.
The footings are in place:
Beech will rot quickly in contact with the ground, so I used the same concrete footings as for the previous shed. Note there is a woodpile right in the middle; there was a second one closer to the camera that I unstacked in a pile off camera. I couldn't bear to do that again, so I built around this stack. Note also the multiple layers of shredded tarp on the pile in the background. This is why I need sheds, tarps cannot survive UP weather.
Here the posts are up and braced:
Because the footers follow the non-flat ground, I had to put the posts up, use a string to measure for the cuts, and then take them down and cut them and replace them one at a time. I soaked the bottoms of the posts in CopperCoat (copper napthenate) and painted all the surfaces to try to ward off any bugs or rot. I used the same on the last shed and I've had no issues.
At this point I got lazy with the camera. I milled 4 beams to run front-to-back, notched the posts, and attached with carriage bolts. For purlins I just used 2x4s from Menards instead of milling those out of beech. Partly because it was quicker, and partly because I don't know how much green beech 2x4s would warp. I ran the purlins between the beams on ledgers, and they are also end-nailed. The roof is 8 sections of 3' x 8' steel, yielding roughly a 24' x 6' storage area (around 7 cords depending on height):
The ratchet strap was used to square up the roof framing before the metal was screwed down, it was a couple of inches off.
Still needing to be done: flashing front and back, some diagonal bracing, and siding (next year). Also filling it up, which isn't going to take long with all the beech dying.
![[Hearth.com] YAWS (Yet another woodshed), from scratch [Hearth.com] YAWS (Yet another woodshed), from scratch](https://www.hearth.com/talk/data/attachments/160/160896-81acd431607c30b8e58e8ba682ae5de5.jpg?hash=aFM_FWdSFq)
![[Hearth.com] YAWS (Yet another woodshed), from scratch [Hearth.com] YAWS (Yet another woodshed), from scratch](https://www.hearth.com/talk/data/attachments/160/160897-7c269d14c1b5efa5b8b6a425eab4d593.jpg?hash=0-qmKoqBtT)
![[Hearth.com] YAWS (Yet another woodshed), from scratch [Hearth.com] YAWS (Yet another woodshed), from scratch](https://www.hearth.com/talk/data/attachments/160/160898-47dedbd0bc6ba6cf08adba13fe11ebee.jpg?hash=MHB7SX075z)
![[Hearth.com] YAWS (Yet another woodshed), from scratch [Hearth.com] YAWS (Yet another woodshed), from scratch](https://www.hearth.com/talk/data/attachments/160/160899-bfc9bf53062136d41c2a3f7138a31f4c.jpg?hash=7uwea-bJSI)
![[Hearth.com] YAWS (Yet another woodshed), from scratch [Hearth.com] YAWS (Yet another woodshed), from scratch](https://www.hearth.com/talk/data/attachments/160/160900-818ac367cf2bd34c5a378b4dfccbd026.jpg?hash=Nzchrv4Vyt)
