If you turn off the main breaker, does the meter still run?
It does not run. But would of been fantastic if it did! Would of explained everything
I dont know anything about smart meters but from reading the above NYT link it sounds like in some places it is possible to do your own monitoring of them in real time. Maybe by adding an app thru your utility or something? Maybe could be checked out? I would still get on getting a monitor though.
It's bizarre. I know you've thought of it, but there was a thread similar to yours and it turned out to be a leaky well pump foot valve, or something like that.
do you have a solar system installed or a tesla type house battery
Didn't know you had a heater in the pump house, or maybe I missed it. That could be a big kwh user, depending on things like how big & exposed & insulated or not the pump house is. And how much it's heating when it's not supposed to be.
You’re using double what you estimate. The number on your meter increases a certain amount per day(=2000/30) and you expect half that. Should be pretty easy to check it every hour to watch it climb steadily or all at once.
This is not something small like too many lights on. Your leak is huge. Shut off the water system breakers for 4 hours and I bet you’ll see that the meter slows down to the rate you expect. (=(1000/30)*(4/24))
If it’s not the water system breakers then try another circuit until you find your pirate.
That's not quite what I'd call slow. Not fast but not slow. Not sure what your cut ins and outs are but that could be around 20 extra cycles per day? A contributor.
The submersible pump foot valve is a likely culprit as I think someone else mentioned.40-60 psi pressure switch. Only thing I can think is its leaking underground.
To lose 2psi with a big expansion tank means a pretty big leak.
I figure 2 psi every 10 minutes is 200 minutes for 20 psi. It would take a 20 psi swing to turn the pump on. So with zero water in the house being used the pump would come on about every 3 hours and 20 minutes. The cistern pump runs about 20 seconds when it comes on.
I don't know how to calculate the electricity usage of a 1/2 horsepower pump since I can't remember what brand it is. I am kit sure if it uses alot of power or not? I'm pretty sure it's a 110 volt pump though.
I do need to find the water leak for sure though but I don't think it's a huge power draw.
Check your algebra, Doc. 2psi/10min = 20psi/100min, assuming linear behavior. Double all your subsequent numbers.
You can use 746 watt/HP to estimate. The actual power use would be somewhat higher.I don't know how to calculate the electricity usage of a 1/2 horsepower pump since I can't remember what brand it is. I am kit sure if it uses alot of power or not? I'm pretty sure it's a 110 volt pump though.
Personally I rely on a clamp-on amp meter but I thought 746 would give Doc something to start with.The FLA of a single phase induction motor is actually close to 7 amps per hp (1600 watts), due to slip and efficiency. However, actual current draw is load dependent, and the load is varying. Furthermore, the pump is selected to never actually hit its full load capacity, so don’t assume your 1/2 hp motor is operating at 1/2 hp load.
So, roll all of that together, and it’d be tough to nail down it’s actual draw. Ironically, your 746 watt number might not be too far off (roughly half it’s FLA) at median pressure.
Best would be to note it’s draw around median PSI (50 psi on a 40-60 system), and use that number.
Out house is tall so to get a decent shower on the upper floor you need that kind of pressure.80? That's kinda high, for us at least. Ours is more like 20/35.
