sloeffle
Some of the OWB's in the list I posted are approved for indoor installation. If they are, then the "waste" heat would be used to heat the space, no different than a wood stove.That couple percent advantage in combustion efficiency is lost many times over in transferring the heat to the home.
Most installations will be outside though. The practical part of my brain agrees with you that the overall delivered heat is probably going to be higher with a wood stove. The engineer side of my brain says maybe. That's probably a rabbit hole that isn't worth going down since we are probably talking a few % either way. Getting folks moved off of 20 - 30% efficient OWB's and over to newer gasification type units is what we should be spending our time educating people about.
