I am sorry but if you want a simple low tech heating solution that doesn't require water treatment why not just use a woodstove?
Don't worry about it. I've figured that out for myself. If I wanted help with that question I would have asked.
Ok just putting it out there. Boilers are inherently much more complicated and require atleast some degree of water treatment. Going with old tech doesn't change thatDon't worry about it. I've figured that out for myself. If I wanted help with that question I would have asked.
Because stainless still corrodes. Copper still corrodes. Pumps still corrode etc.Yes, obviously water stoves are inherently much more complicated. Why would stainless steel water stoves need water treatment, though?
I'm confused, water treatment is too much pollution, but smoke is ok?
That depends on the allow of stainless and the quality of design and construction.I realize none of these components are going to last forever with or without chemical treatment. My understanding is that stainless steel would last a lot longer without treatment, though.
If stainless was such a great idea, everybody would be using it
If you don't mind the smoke, the water additives are the least of your worries, and much cheaper than premature boiler or pump replacements.If I could avoid using water treatment by getting a stainless steel stove (and perhaps replacing my pump a little more often), that would be highly preferable to me. On the other hand, the smoke from my Taylor, which I used for about 13 years until I drained it about a month ago, never bothered me, and I would be happy with a replacement stove that was no different with regards to smoke.
The pollutants in the smoke are far more toxic than those in the water. I used to live in NC, in the Piedmont as well. You don't have a massive heating load, so I know your stove spends a lot of time idling. When there is no call for heat, that stove is just a charcoal producing smoke factory, you must not looking when it's happening. A modern EPA approved downdraft boiler will produce almost no smoke at any time in the burn and use less wood (not a big selling point when you live in NC). You are actually looking for a coal fired boiler if you want to buy new, otherwise you are just going to buy a used boiler that still needs water treatment.Maybe for you. Not for me.
When do you even notice the smoke from stoves like my old Taylor? Just when you have the firebox door open?
Unless you use a closed system boiler (not really possible with an outdoor unit)
You will save money in the long term if you get an updated EPA boiler
I really am curious why you are so set on using a boiler honestly. A simple woodstove is far less expensive and complicated and it works without powerBased on what? How am I supposed to research how toxic the water treatment ingredients are if I can't even get complete ingredient lists because the ingredient list is proprietary?
But that gets back to my last question: when would you even notice the smoke? If there's smoke going up and out the chimney and blowing away, why is that such a big deal to you?
I have a neighbor with a Taylor, much like mine but a little newer -- he's had it at least since 2007 when I first moved here -- and he said he doesn't ever add any water treatment to it. If 15-20+ years is possible in a Taylor without water treatment, how much life is possible with a stainless stove without water treatment? And how long can a water stove be expected to last even with water treatment? What's the oldest water stove anyone on this forum is using?
Why not? Just curious.
Money? Besides the cost of the stove, water treatment (which is a separate question from whether I get an updated EPA stove or not), a small amount of electricity for the system, chainsaw expenses... what dollar costs are there? Are you saying the difference in electric and chainsaw dollar expenses alone would pay for an updated EPA stove long term?
So It’s ok to fill the air with chemically bad stuff from a choked or idle fire in an ODB but it’s not OK to treat the boiler water with an rust prevention additive because you don’t know what’s in the bottle.
I went from a wood stove, to a wood furnace, and will be installing a EPA approved OWB this year.I really am curious why you are so set on using a boiler honestly. A simple woodstove is far less expensive and complicated and it works without power
I have absolutely no issue with clean burning outside burners. They aren't for me but to each their own. I was just pointing out that his desire for simple no frills heat doesn't really fit with an outdoor burner. And btw I have never gotten up in the middle of the night to load any of my wood stoves. If I had to do that I wouldn't be heating with wood. I also really don't see how an outside burner could be more efficient than a good modern stove. Cooler bedrooms is definitely an issue but one I actually prefer. But again not saying there is anything at all wrong with your choice.I went from a wood stove, to a wood furnace, and will be installing a EPA approved OWB this year.
Wood Stove = bedrooms were always cold ( ranch home ), mess in the house, needs fed in the middle of the night, house smelled like smoke sometimes when you would get a "wind event", as I get older I respect fire more.
Wood Furnace = needs fed in the middle of the night when temps are really cold, mess in the basement, tired of babysitting ( this has more to do with the model I have ), tried of tearing up my yard bringing totes of wood in ( again, my particular situation ), as I get older I respect fire more.
OWB = mess outside, fire is outside, more efficient, 12 - 24 hour loads, Uncle Joe is giving me 26% of my money back.![]()
The wood stove was a mid-size Dutchwest catalytic stove ( 6" flue ). Smallish firebox, so maybe that was part of the issue. I'd load it at 10PM and would have to generally reload it at 3 or 4AM.And btw I have never gotten up in the middle of the night to load any of my wood stoves.
The EPA numbers don't lie.I also really don't see how an outside burner could be more efficient than a good modern stove.
That couple percent advantage in combustion efficiency is lost many times over in transferring the heat to the home.The wood stove was a mid-size Dutchwest catalytic stove ( 6" flue ). Smallish firebox, so maybe that was part of the issue. I'd load it at 10PM and would have to generally reload it at 3 or 4AM.
The EPA numbers don't lie.Both lists were sorted by efficiency and fuel type as being Cord Wood.
Wood Stove / Room Heater
OWB
I believe the real reason that the EPA approved OWB's can achieve such a high efficiency is via downdraft gasification. My assumption is, there isn't enough room in a wood stove to do that. I'm buying a G4000 which is rated at 82% efficient, my current wood furnace is 76% via old EPA test, can't remember what the Dutchwest wood stove was rated at. Minimal % gained in my for my situation, but I'll take it.
