M
MasterMech
Guest
Somebody is going to tell you to run AVGas (the 100LL variety most likely) in your saw.
![lol ;lol ;lol](/talk/styles/default/xenforo/smileys/lol.gif)
Get 100LL AvGas from your local airport.
It never goes bad. It won't gum up your carb. It'll make your saw easier to start.
The one you mentioned is 35mi away, and a Marina not open in winter, I did find another station 20mi away but ,40mi to go get some gas ?Workable? I always prefer an alternative to bending over and spreading them wide myself. There are good reasons why there is a huge backlash against ethanol in gas nationwide, and sites like Pure-Gas and lobby efforts against it.
As for a lack of ethanol-free gas being available, there are over 200 gas stations and marinas in NY state that sell it. I dunno where in the Hudson Valley that you live MM, but here is a list of NY stations: http://pure-gas.org/index.jsp?stateprov=NY
As for 'zero' places around Grand Blanc that have ethanol-free gas??? I see one listed in Waterford (not far south of Grand Blanc on my map). The list for MI: [URL='http://pure-gas.org/index.jsp?stateprov=MI[/quote']http://pure-gas.org/index.jsp?stateprov=MI[/URL]
Still waiting for someone to build a saw to run E85. You can make big power on alchohol.
Gonna drink fuel quick for sure but might be fun!
I have thought about converting my big truck to run E85 exclusively but only a couple stations around here and I don't pass them frequently.
E85 also gets you about 33% less gas mileage.
One other comment about octane. Don't forget that in Europe they use RON to label fuels, not the AKI method (RON+MON/2) we use here. I beleive that in many countries over there the typical fuels are 91 RON (87 usa), 95 RON (90 usa) and 98 RON (93 usa) If you buy a European brand saw (Stihl, Husquavarna) and the manual calls for high octane it might be worthwhile checking if it really needs our high octane gas or its just a direct translation of the Euro spec.
That's huge. Couple people I know of that run it in their newer vehicles and see a 2-3 MPG drop in mileage. That's roughly a 10-12% drop. If that 10% applied to my big truck, I would see less than a 1 MPG reduction.![]()
Well, I do not know where they get those numbers. Do the math: E85 is 85% ethanol (summer blend). Ethanol has 60% of the energy of gasoline. 15% is the same, add 85% multiplied by 60% to that to get a result 51%, and so 15% + 51% = 66%. So E85 is 34% less fuel efficient than standard (E0) gasoline. Comparing E85 to E10 which has 4% less energy than E0, E85 has 70% of the energy of E10, and is 30% less fuel efficient. Even comparing E70 (winter blend E85) to E10, E85W has 76% of the energy of E10, or 24% less fuel efficient.
10%? no way Jose....![]()
I didn't know there was a station that distance ,now I do ,thanks for the info.Well, you said there was zero availability for E0 gas for you. Now you want things to be more convenient? I have to go 15 miles each way to get E0 here, and I am happy to do it. I fill up a 5 gallon can of E0 on my way to town once or twice a month. It has zero impact as I have to go 20 miles one way just to go to the grocery and hardware stores anyway. If you add StaBil like I do, the gas will stay fresh for a year (in the can and in the saws). Double the amount of Stabil and it will stay fresh for two years. And w/o any ethanol in there, there is no moisture absorbed by the gas over time and no chance for phase separation. It works for me... I guess it all depends on your use, priorities and investments. I have a lot of 2-stroke equipment that I use all the time and money tied up in them, so for me its a no-brainer.
I'm only reporting what they tell me. I don't have a flex-fuel vehicle to try E85 in myself. I don't think I'd be burning off a lot of it in a daily driver if the 30% number turns out to be right on.Are they sure its only 10% ? Ethanol has a much lower BTU content per gallon (70k vs 115k if I recall) and runs at a much richer ideal A/F ratio (8:1 vs 14.7:1)
Already discussed this. I run a 50/50 mix in my race car (it's tuned to run on it) and you can smell the fumes from feet away. Do you want to be breathing that in from a muffler that is 3ft your face?
Avgas? I wouldn't bother for many reasons:
- Current going price is about $6.50 a gallon
- Other than being ethanol free, 100LL doesn't have anything magic in it that will make it store longer than pump gas. Gas goes bad from the hydrocarbons oxidizing - I'd still use stabil/seafom/etc for storage.
- It does have better quality control and better additives so the equipment will run a little cleaner. Would you notice a real world difference in a saw? probably not unless you leave old gas sitting in the carb for years unrun.
- Assuming the saw is designed for 87 octane you will have slightly less power output (remember, the higher the octane the lower the specific energy of the fuel)
- As Jags mentions, it has a lot of lead in it - 2 grams of TEL per gallon, whereas back in the day leaded mogas had something like 0.1g TEL/gal and that was bad news. I wouldn't want to use it. There is talk of it being banned eventually in aviation as well.
- Also the high lead content of 100LL can foul spark plugs over time if the motor is not designed for it like aviation engines.
Yes. I'm no chemist, and I'm guessing you're not either, but why would you think think that the god-knows-what in pump gas is any better for you at 3' than AvGas?
So you're saying that occasional proximity to the exhaust fumes of leaded gasoline is analogous to eating chips of lead based paint?
Rilly?
