Actually in the US, premium fuel has slightly more energy than regular (up to 1%). Summer grade gas also has more energy than winter grade (about 2%). Pure gasoline also has about 4% more energy than E10 blended gas does. Also adding premix oil does lower your octane, its not a myth. It varies with the type of oil though. Also what is not mentioned here is the fact that gasoline drops in octane once it leaves the refinery, and keeps dropping in time. That is why pump octane ratings in the US are an average of refinery octane and the octane tested when it is pumped into your car at the gas station. Meaning that the actual octane of the gas is likely lower than that listed on the pump. And it continues down from there. That's the main reason I use gas stabilizer in my 2-stroke gas, and I add it at the gas station when I buy my gas (that holds for all gas: E10, regular, super, AVgas, etc.)
The octane "myth" started long ago, when they realized that higher compression gas engines resulted in more power. So they increased gas engine compression and then realized that in turn created engine knock/pre-ignition which resulted in damaged engines. So they increased the octane of the gas (with lead) to even out the burn and prevent pre-ignition, and as a result got 'more power' using higher octane and increased compression.
And yes, you can advance or retard the ignition timing in a 2-stroke. Just move the coil up or down relative to the magneto in the flywheel, or swap out the coil with a differently timed one. As for using regular gas in chainsaws, you have a higher risk flaring or uneven burning using that stuff. Uneven burning causes uneven pressure at TDC, and that in turn can cause piston tilt, which in turn can cause scuffing of the piston skirts and cylinder walls. For this reason most chainsaw manufacturers require you to use mid-grade US gas. Also whatever the gas or premix oil you use, re-tune the saw if you change them. My saws all rev higher with pure gas vs E10, and they also rev higher using 100% synthetic oil vs dyno oil.
I agree you can get a little more out of better fuel. But when your already bringing the right tool for the right job its just an no-issue. No if you jump on a project that put your saw to its very limits I will run it and wished I passed on the job.
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
RUN Forest Run! ( Check out the truck)
![Eek! :eek: :eek:](/talk/styles/default/xenforo/smileys/bigsurprise.gif)
![Where to buy the BEST gas for my saw... Where to buy the BEST gas for my saw...](https://www.hearth.com/talk/data/attachments/100/100339-65232dfde36ea00ac54de9e10fd102d0.jpg)
