Yeah, getting in there and moving stuff around does often help. I'm often torn between letting it ride and going back in, as it's often the splits on the bottom of a 3 cu.ft. firebox that need rearranging, and with a deep coal bed my only access (without dumping hot coals out the front of the stove) is thru the top-load door. It's easy enough to move the splits on top, but hell to get at the ones on the bottom of a firebox that big and full.Did you try just poking things around in there? [...]
Also, oddly enough, putting some smaller dry stuff on top of whatever isn't burning right seems to draw the flame upwards to engulf the misbehaving split and get it going better than if you put the dry stuff underneath it, which is intuitively what you'd do.
I've not tried putting dry stuff on top! As you suggest, I figured that if I didn't do the preemptive move of putting them on bottom before loading, it was too late to do much about it. I'll try this next time.
I like this idea, as I almost never have trouble getting light-off with half loads, only when I stuff the stove full. This will mean committing more time up front to my re-load, wait, engage cat, lower throttle cycle, but it may actually save some time in the long run.I also do not do a full reload I do it in two stages so the stove is hot and have a good draft before topping it off.
