So Fireview was at 550 STT or 550 Cat . At what STT would the F45 have to have for equal BTU output? Tough question.Load of Red Oak with air setting just a smidge open.
That is a tough question! I’m not sure you can base the BTU output by the stove top temps alone. The Fireview releases the heat slower and steadier than the F45. A similar load in the F45 would probably run a hotter stove top over 600 then fall off quicker. Pretty close BTU output between the two just released different.So Fireview was at 550 STT or 550 Cat . At what STT would the F45 have to have for equal BTU output? Tough question.
I restarted this morning after 3 days of cold stove as we had warmer outside temps. 34.4 low this morning with wind. 66.4 low in family room, heat kicked on at programmed set up time. Arggggg. Had stove preloaded, just needed to be lit.....Normal startup with 4 splits oak/hickory and some kindling. Ahhh 71 in FR now
