What Is In Your Stove Right Now?
Woke up to
[Hearth.com] What Is In Your Stove Right Now?
So I made this
Siberian Elm split in front bottom
White oak bottom back
Bone Dry rotten oak and hazel in the middle
Poplar (bone dry) shavings made with my block plane
And all the twigs on top are apple
I’ve seen others using plane shavings and thought I’d try it myself…works great, BUT, you need a lot!
The cat is thinking "what are you waiting for??!"
That Jupiter is a huge feline (over 13Lbs) and he's just enormous, not fat...huge bone structure
he is a full blown racist...he gets along fine with my cream tabby and newcomer stripey Anika
but he wants to kill our black cat
The reason I posted that photo of Jupiter is because my previous fire -worshipping feline, Fif, whom I have posted a lot of photos of, passed away this past May...Jupe seems to have taken up the mantel
but he wants kill our black cat
Does that Panadero not have secondary burners?
Reactions: ctreitzell
28 degrees with howling winds and a couple inches of snow on the ground. Firing up the coals and going to go with a full load of hardwood I think.
At the rate we’re going I don’t know if we will ever see snow this year. Very mild as of yet.
I don’t know what that means 😬
***edit…ok, I looked up secondary burn functionality
This Délice/Dover claims a 77% efficiency
I think the design of air intake in the bottom (with door closed) and the deflector fins hold gasses in the top of the stove. Further, I noticed the flue pipe outlet is greatly obstructed by the rear fin and I suppose impede gasses passing so they stay longer in the stove
But I’m guessing…I don’t know if it’s any more. Implicates than that
Glass is very clean, air intake is set waaaaaay down to about 5%
But it is howling, blizzard-ish wind, so draw is quite strong
RealFeel says -12C
Currently in the stove is
White Oak/Siberian Elm/ Poplar on the right (I have a bit of poplar left over and some of the shapes are stack breakers). This is all wood from my property currently…the stuff I buy in isn’t cured long enough afaiac and causes me issues.
Update.... last night, I started that fire that I thought would be just to add a bit of warmth in natural convection.
While I had the top down fire started with just a couple splits on the bottom, I put the fan limit switch in manual mode. I started fiddling with the wires and found a loose connection. The blower fired up! Added more splits for a hotter fire than planned. Redid the electrical connection after pulling the fuse. Once done, put the fuse back in with limit switch on auto. Couple minutes after, the furnace started doing it's usual run cycles. What a relief.
Don't recall what I had in the furnace last night but had some nice coals about 10am. Added some sugar maple, couple soft maple, and a round of black cherry. Nasty wet cold set in today. Damp chill that would soak into the bones. So glad the furnace is GTG.
First fire. Barely defensible with my "rule" of no fires unless temps are below 45 for 24 hrs or more. 39 tonight, 46 tomorrow, 40 tomorrow night.
But windy, rain, clouds - so no solar gain and more heat loss.
Aka I needed a fire...
Three 7" maple splits e/w on the bottom (slightly too large for n/s), a few oak shorties, a pine ugly, and some splitter trash to light it all up.
  • [Hearth.com] What Is In Your Stove Right Now?
Some branch wood, small and medium sizes,1 split, and a couple shorties. All Doing a good job driving away the wind and rain chill outside. Feels good in here.
Helps drying out the dogs too. And their wet towel above the stove.
well, I'm lettin it go out...0300 CET here
last embers burning off over the next hour
time to get some shut eye
start anew again tomorrow
I've been doing overnight burns the last couple years
daily starts I'm not looking forward to...oh well
We have an outside temp of 38.5 tonight, the basement temp is 79 with the temps up here 70 & 72. I did have a fire earlier with some pine, the last I looked there was still some coals.
I'll have an overnight fire, I'll load the Liberty up with pine.
Temps in the high 30s tonight. Still damp and chilly out with a dusting of wet snow. Looking forward to spring .... LOL
Been burning mostly ash with a couple birch splits, in small batches throughout the day.
Well, not as easy a start as yesterday…
Started with S Elm / Oak/ Poplar with poplar shavings and apple twigs
Now, 2nd reload is 1 Ash/ 2 Oak
Reactions: Wildflush
