What Is In Your Stove Right Now?
We had 41.7 this morning, the basement temp started out at 66 with the temps up here at 68, I cycled the furnace last night for about 7 to 10 minutes last night.
I started a fire this morning, that felt good while having coffee.
Mini split running this morning. No fire now. Will start one later this afternoon as it will be cool for the next few days.
Reactions: thewoodlands
The outside temp tonight is 36, the basement temp is starting out at 75 with the temps up here 70 & 71.
I did have a fire after supper, tonight we have another load of pine going in the Liberty.
We had a low of 28.6 this morning, the basement temp started off at 70 with the temps up here at 68 & 69. Another shoulder season fire was started before coffee.
Reactions: MRD1985 and NickW
Cold air.
Still damprid.
I did connect the stove pipe again; it's no longer humid outside.
Used the mini split twice so far. Long range forecast says the stove may only be out around November 30...
We had a low of 43.5 this morning, I'm not sure what the basement temp was but up here it was 68 & 69 before a fire. I shut the fan off when the basement temp hit 77, the temp up here is 71.
Last night the temp up here was 72 so we didn't have a fire.
Reactions: MRD1985
It's 36.1 out tonight with a forecast low of 29, the basement temp is starting out at 75 with the temps up here 70 & 71. We have another pine fire going in the Liberty for some overnight heat. I did have a fire after supper tonight, more pine.
Going down to 34 tonight so our coldest night so far. Fired up a load a cherry, elm, and maple split surrounded by uglies. One piece of fatwood, a pinecone and some kindling got things going. STT 550 main floor went from 67 to 74. House will hold the heat for the night. Cold start in the morning.
We have an outside temp of 34 degrees tonight, the basement temp started off at 73 with the temps up here 70 & 72. The overnight load is going in the wood stove, another load of pine.
NOAA has a forecast low of 25 for our area tomorrow morning.
Back home after the weekend in the Northwoods. Currently 43. 2 big ash splits, a 6" beech round and 3 chunks of aspen in the NC30.
Reactions: MRD1985
We have an outside temp of 32 degrees this morning, the basement temp started off at 70 with the temps up here 68 & 69. A load of pine is going in the wood stove.
36 this morning. Load of maple, cherry and oak with uglies in the gaps. Did not have a fire last night so main floor is 64. Got STT to 625. Main floor 71 now.
33 tonight. Loaded up the Vista. All uglies. Mix bag of wood. Good draft had to shut things quicker tonight. Cruising at 600STT.
Temp will be 77 on Wednesday. Crazy weather pattern. Dry Fall here. Lots of brush fires.
We have an outside temp of 35.4 tonight, the basement temp is starting off at 75 with the temps up here 70 & 71. Another load of pine is going in the wood stove.
We had 35.2 this morning, the basement temp started out at 70 with the temps up here 68 & 69. We did our two loads of pine this morning, the temps up here are 70 & 71.
Reactions: MRD1985
We had a storm move through that gave us some rain that we needed along with some thunder & lightning. The outside temp tonight is 49.6, I had a fire in the wood stove after supper that had the temp in the basement at 77 with the temps up here 71 & 72. We won't have a fire tonight.
Reactions: MRD1985
We had 56.7 for an outside temp this morning so no fire. The temps up here were 70 & 71 before the first cup of coffee.
Reactions: Gearhead660
