It's 38 outside right now. Our heat pump is older and the resistance kicks on at 37 degrees so any time it's below 40 I use the stove. It's a 2006 r-22 Trane so we're treating it like a used car. Once it becomes more expensive than it's worth to fix we'll replace it. They won't recharge it anymore after they did it when we first moved in and r-22 is outrageously expensive and rare nowadays.Same way I do it. Coals toward the front. Smaller maple split to get things going.
Must be colder in your part of Mass. 45 here so heat pump at times to warm things up. Have not had a fire yet.
Agree I don’t light the stove until it’s below 40.It's 38 outside right now. Our heat pump is older and the resistance kicks on at 37 degrees so any time it's below 40 I use the stove. It's a 2006 r-22 Trane so we're treating it like a used car. Once it becomes more expensive then it's worth to fix we'll replace it. They won't recharge it anymore after they did it when we first moved in and r-22 is outrageously expensive and rare nowadays.
Yep. No sense changing if it still works though. I suspect it'll be in the next 0-2 years it gets swapped to a modern whatever replaces R-410a system.Agree I don’t light the stove until it’s below 40.
Yes R-22 Freon is very expensive and being phased out due to harm of the ozone layer.
