Well egg on my face. This has not been my week. I didn’t do the equation i just (wrongly) 100c=212f then 200c=424. I see my mistake now!By my math, 200 degrees Celsius is 392 Fahrenheit. I'd say it's pretty close
Dont worry we all have days like thatWell egg on my face. This has not been my week. I didn’t do the equation i just (wrongly) 100c=212f then 200c=424. I see my mistake now!For anyone else stumbling across this in the future
(200°C × 9/5) + 32 = 392°F
Thanks for setting me straight.
I have an Osburn tube stove. I definitely find the EW loading is more controllable when real cold. I also have a tall chimney and can run away if not closed down pretty quickly.And that my friends is reloading am EW tube stove in a cold snap. Pretty easy and quick process with good wood and a strong chimney.
I think the mistake a lot of people make is waiting too long to the the air down and let it get way too hot. This wastes wood and can damage the stove. I find shutting it down as soon as possible gives me the best and most even cruises. I mostly just go by visuals in the firebox. The flames don't lie! With a recessed insert a flue probe isn't an option and STT temps lag behind a little bit.
I had previously been doing NS loads as I can obviously load more but the temps run hotter it you're on top of it. I can easily get overnight burns with a partial load in the 3.3 cf firebox. I like to mix it up though and I basically only burn red oak for the next couple years then I will have other stuff in the queue.Yes absolutely. I usually save up my shorties to do a N/S load here and there for fun and it can get out of control fast if you don't watch it. I'll usually only do 1/2 to 2/3 loads this way. The design of the airwash and doghouse is really for EW so it's not surprising. N/S orientation gets more air.
Even EW the stove likes to burn and will run away if you let it when its cold out. I typically like to just relax by the stove with the dog and get the air down ASAP for best results. Then it's just set it and forget it for 6 hours give or take depending on the load. It's not a huge stove only 1.85 cu ft.
I had one small overfire incident this year where I got distracted post reload and hit 850 STT for a 15 minute period. Everything was OK and I got it under control quickly but it was scary for sure.
Great info and thanks for videos...i been using pe summit for almost a month now and turning the air down early does help me. Having a blower fan is a neat trick to control the stt. I have not purchased that yet..Yes absolutely. I usually save up my shorties to do a N/S load here and there for fun and it can get out of control fast if you don't watch it. I'll usually only do 1/2 to 2/3 loads this way. The design of the airwash and doghouse is really for EW so it's not surprising. N/S orientation gets more air.
Not so much a thumbs up sinking in molten metal as a fist bump sinking in a pit of coals!
I live to entertain and educate the people! I'm currently laid up on the couch waiting for my am pain meds to kick in. The mornings are the worst.Not nearly as exciting as Caw’s tutorials
