Pine doenst contain any more creosote then any other wood, how wood is seasoned is what determins the creosote buildup in the chimney. Pine, IMO has less chance of creosote buildup due to the low density and a high combustion rate.
Stick with the 6". 8" chimney is more forgiving at your altitude then someone at sea level, but your stove will perform better on a 6 inch flue. 30' is plenty of pipe for 6", i would be afraid of overdrafting the stove on 8". I have 24', 6" chimney at 9000' and my stove drafts perfectly. Remember, manufactures are going to be conservative with there recomendations.
My last point would be that most modern stoves run on 6" flues, the trend seems to be going to smaller flues with every new generation of stove. When your stove wears out, i think you would be better prepared for a replacemnet with a 6" chimney in place, who knows, in 10 years the standard might be 5...
here is a quote from
http://www.mastersweep.com/wood.htm
"Back in the early 1980's, tests were conducted to discover which kind of wood created the most creosote in a regular "open" fireplace. The results were surprising. Contrary to popular opinion, the hardwood's, like oak and madrone, created MORE creosote than the softwoods, like fir and pine. The reason for this, is that if the softwoods are dry, they create a hotter, more intense fire. The draft created by the hotter fire moves the air up the chimney faster! Because it is moving faster, the flue gas does not have as much time to condense as creosote inside the chimney. Also, because the flue gas is hotter: it does not cool down to the condensation point as quickly. On the contrary, the dense hardwood's tend to smolder more, so their flue gas temperature is cooler. Thus, more creosote is able to condense on the surface of the flue. So, saying that "fir builds up more creosote than oak" just isn't true! It is a misunderstanding to think that it's the pitch in wood which causes creosote. It's not the pitch that is the problem, it's the water IN the pitch. Once the water in the wood has evaporated, that pitch becomes high octane fuel! When dry, softwoods burn extremely hot! "
