seaken said:In my opinion, you should have installed a masonry heater. But given the choices of wood stoves you have discussed here I would consider carefully my own ability to maintain the entire system. If you are a good mechanic, then choose the Defiant catalytic. If you tend to avoid mechanical work, choose the PE. Also, consider your budget. The chimney for the Defiant will cost more. And you can expect about $150/year for repairs and maintenance. The cost per year of maintenance for the PE will likely be under $50. Although, depending on some variables hard to predict, you may break even on yearly costs due to the increased efficiency of the catalytic system.
I also think you are trying too hard to get the perfect stove. I think any of the stoves mentioned can be your perfect stove. Don't get so caught up in the minute details that is prevents you from making a decision. I don't think you have to fear making a mistake when considering any of these stoves. I would choose based on the feature set that I liked the best. Sounds like your wife favors the Defiant. That should be enough to swing the decision in favor of the Defiant. Especially if you like the top load and warming shelves, etc. The PE is a fine stove. But no top load, no warming shelves, no double-door open "Franklin style" ambiance, etc.
Good luck. And welcome to the world of wood burning.
Sean
Hey Sean,
What exactly are these yearly maintenance and repair costs you talk about?
