Vermont Castings Defiant Cat issues
xanadu1797
43
Eastern PA
Hi everyone,
I’ve been trying to figure out the cat on a Vermont Castings Defiant. It behaves like this-
With the cat damper closed (mechanism is broken) the thing will fire but it doesn’t level off and climbs past 1600 where I have the alarm set.
With the cat damper open the cat doesn’t fire at all. Or alternately if it’s ripping up around 1500 and I open the cat damper it usually descends to 600.
I’m guessing an air leak is most likely as I refitted the stove but the griddle temps are reasonable- usually between 300-600 but most often 400-500 during a run.
How do I tame this cat?
Which model Defiant?
(mechanism is broken) - What is broken and how is it being operated?
How old is the cat?
I think it’s a 1945. It has the cat chamber that’s made out of that fiber material as a box- not ceramic brick.
There is a mechanism that is meant to open and close draft directly to the cat which operates like the stick on thermometers do- a little coil of metal is attached to a wire that opens and closes the door. Closed when hot, open when cold.
The cat is new-ish. Hasn’t been in operation for but a season or two.
The age of the cat rules out new cat hyperactivity. What is broken?
Has the condition of the refractory package (the engine) been checked.
Yeah I replaced all those parts. The box the cat sits in is new.
The damper mechanism for the cat doesn’t work. I didn’t replace that because I saw multiple members here recommended closing it with a magnet and being done with it.
Do you mean the thermostatic air control? I thought the magnet was to stop it from tapping when in the neutral position and to ensure solid closure, but not to disable it. I that is closed, then it sounds like excess air is getting into the fire. Check the ashpan and door gaskets first.
I am not an expert on your model (or any model for that matter) nor do I fully understand your circumstances. But, if you have the secondary air fully closed that may be why the cat is getting so hot, maybe not enough air to dilute the exhaust and bring the temps down?
Have you tried opening it up a bit?
Hi everyone,
Cat damper?? The cat damper on my stove is inside the stove and directs the smoke so that it goes into the cat chamber. If I close my cat damper and direct the smoke to the cat chamber the temperature will climb past 1600 if I don't control the air intake. And yes if I open the cat damper and direct the smoke directly up the flue my cat will cool. The taming of the cat is controlling the air intake.
My stove has a secondary air shutter on the back of the stove. It is a small shutter with a thermostatic coil that has a probe that goes into the cat chamber. The shutter is partly open when the stove is cold and when the cat heats up it closes. Mine will open if the cat gets extremely hot and my theory is it cools the cat chamber with outside air. I replaced mine and they are available on Amazon.
Reactions: stoveliker
