Hi everyone,
I’ve been trying to figure out the cat on a Vermont Castings Defiant. It behaves like this-
With the cat damper closed (mechanism is broken) the thing will fire but it doesn’t level off and climbs past 1600 where I have the alarm set.
With the cat damper open the cat doesn’t fire at all. Or alternately if it’s ripping up around 1500 and I open the cat damper it usually descends to 600.
I’m guessing an air leak is most likely as I refitted the stove but the griddle temps are reasonable- usually between 300-600 but most often 400-500 during a run.
How do I tame this cat?
