Awesome! Thank you. I would’ve never though to cover that to check. Great info.I have the dauntless. It does sound like a blowtorch at times. If you reach behind it, and put your hand over the air intake at the bottom, the noise stops. So it’s not a chimney fire or overly active catalytic burner, it’s just a noisy intake. It does settle down once that internal dual metal door starts working as advertised. Not a fan of the dauntless, but it’s a normal sound. You’ll hear it, to some degree, as the adjustment door opens and closes too.
Hi. We have the Dauntless and have been dealing with same issues. Taked to dealer several times which was no help. We have an outdoor air intake pipe near back of stove because our house is so tight. This morning I covered part of the air-intake on the stove and it helped a little. We bought this stove to load up and go to bed. So far that has not happened because it makes us so nervous. Very frustrating.If anyone has a Vermont Castings newer stove, I would love to get an educated answer.![]()
I bought a Vermont Castings Dauntless, and so far, it’s been anything but. The one remaining problem I’m having, which no one seems to be able to answer, is that right after reload, no matter the temp, as soon as I close the bypass, it sounds very much like a blow torch.
I am trying to figure out why this happens. Is it gases building in the firebox, is it the catalytic combustor? Which if so, would seem odd that would kick in at a low temp, (low temp only because I tested it to see if it would happen at lower temperature.)
The reason I’m struggling with this is…in the manual, it says if it sounds like a blowtorch, it’s over firing and can cause loss of life. Seriously? Yet, Vermont Castings customer support is nonexistent, and anyone I’ve spoke to in the industry says, ‘I’m sure it’s fine’, without having a clue. I really need an answer so I can burn without worrying I’m doing something wrong. Any help is greatly appreciated. I’m really hopeful someone will have a solid answer.
There are plenty of good answers in this thread. I feel your pain, it is definitely nerve-racking, and makes it impossible to use the stove in a normal way.Hi. We have the Dauntless and have been dealing with same issues. Taked to dealer several times which was no help. We have an outdoor air intake pipe near back of stove because our house is so tight. This morning I covered part of the air-intake on the stove and it helped a little. We bought this stove to load up and go to bed. So far that has not happened because it makes us so nervous. Very frustrating.
Let me assure you, I still feel the same also. I wonder if the fear of that sound will ever go away, but I hope after all these responses, eventually I’ll have some peace with it. 😊 Cheers to anxiety free burning.I have a defiant Flexburn and take GREAT comfort that Halliewest is experiencing that chimney fire sounding WHOOSH.
Mine scares me to death, even though I now know that the sound is "a thing," I am still never 100% comfortable when I lay my head on a pillow.
The first time I heard it, I called the fireplace shop and they told me that I'm probably having a chimney fire. They are VC dealers and even they didn't know about the blowtorch afterburn woosh noise!
Thanks to all that replied, and thanks Halliewest for singing out. I'm glad I'm not the only one! :D
Great info here, thanks contributors!! Yes, this roar can be disconcerting, and I still can't make sense of it. Current manual says it's a problem, but with the OLDER catalytic stoves this was a GOOD sign that the gases were being burned by the catalytic converter. So when I notice a slight burner noise when closing the damper, regard that as a good burn.A lot of us use he Auber AT100 with a high temp thermocouple. Very practical but it's got a bit of what my wife calls a "90s alarm clock" vibe to it.
I recently posted links to both items hereThank you very much. I’ll check it out.
I am so glad to find your post. I just purchased the VC Dauntless Flex Burn in fall of 22 and have over the last 2 months oriented myself to its operation, re-reading manual and checking with supplier as I am quite cautious. It is bigger than my prior wood stove and more intimidating at this point. I have the exact same issues and could not have said it better than your above post - after having bed of coals and continuous use over three days of no power and very cold temps outdoors, I loaded it up hoping I would get more than three hours of good heat, to sleep through the night. Within 20 minutes (cat in zone, and around 400 degrees (obviously damper closed) the fire box lit up like a fireworks show and did the blow torch action. This repeated 3-4 times with 5 minute break in between blow torch events. I closed it down and hoped like crazy for the power to come back on and could use my other source of heat. It makes me very nervous, the manual says it is dangerous but doesn't say anything to help solve the problem. Manual again says if sounds like blow torch its over firing and can cause loss of life. Now what - going. have read all material i can get my hands on - and still not comfortable about how to prevent it or have it not happen, I wanted a simple solution to my power issues and not looking for anxiety - thank you for helping me figure this out. The responses to me surround your main issue and not focused enough for me - I will re read and take notes this time I guess.If anyone has a Vermont Castings newer stove, I would love to get an educated answer.![]()
To me, This is not normal and if it is, I made a huge mistake in purchasing this - It appeared that it was going to explode. During a power outage in zero degree weather. Shut it down. Have closed damper many times, this never happened before -It’s normal to sound like that after closing the damper. That’s the sound of the gases running through the combustor
It can be dangerous if the cat goes above 1400f or so. Dangerous being may damage the cat. The "wosh" sound is the air going through the combuster which acts like a venturi on a carburetor. More so the hotter you have the flue typically. It's all that draft being squeezed through that combuster rather than the damper which has a bigger opening. Usually that draft will settle down through the combuster after a few minutes. What can exacerbate that "wosh" is having wood placed directly against the conbuster and/or its opening. It is super important to have a good coalbed in the stove but all of it doesn't have to be crammed against the combuster opening. If it takes all the coals to get a few inches up against the combuster then probably not enough coal base in the stove.I am so glad to find your post. I just purchased the VC Dauntless Flex Burn in fall of 22 and have over the last 2 months oriented myself to its operation, re-reading manual and checking with supplier as I am quite cautious. It is bigger than my prior wood stove and more intimidating at this point. I have the exact same issues and could not have said it better than your above post - after having bed of coals and continuous use over three days of no power and very cold temps outdoors, I loaded it up hoping I would get more than three hours of good heat, to sleep through the night. Within 20 minutes (cat in zone, and around 400 degrees (obviously damper closed) the fire box lit up like a fireworks show and did the blow torch action. This repeated 3-4 times with 5 minute break in between blow torch events. I closed it down and hoped like crazy for the power to come back on and could use my other source of heat. It makes me very nervous, the manual says it is dangerous but doesn't say anything to help solve the problem. Manual again says if sounds like blow torch its over firing and can cause loss of life. Now what - going. have read all material i can get my hands on - and still not comfortable about how to prevent it or have it not happen, I wanted a simple solution to my power issues and not looking for anxiety - thank you for helping me figure this out. The responses to me surround your main issue and not focused enough for me - I will re read and take notes this time I guess.
Not sure if there is a draft issue here or not (too much maybe) but regardless of that VC stoves do not run well with the primary all the way closed. Also the size, MC, and species of wood an play into this. But getting back to the draft, if it's more than 0.065 (in the installation manual) it may be too much for the design of the stove (according to VC) and yes a damper may need to be employed to temper it. Also wood can be too small and/or too dry where be it wood off gass to much at one. IMO theses are not overnight stoves whereby you can after 8 hours throw wood back in and go. This no matter much you try and close it downtown extend the burn time. The glass on these stoves will not stay clean no matter what. My dealer told me not to expect the glass to stay "clean" no matter how it's run. He told me this before I bought it. However this is the Inrepid not the Dauntless. Trying to "simmer" these stoves will blacken the glass even more quickly. To keep the glass even semi-clean for a few days they need to be run fairly hot.Hi, I also am glad to have found this forum. I have posted in a few areas about the troubles I have had with my dauntless flexburn. I really tried everything and begged my dealer to help me (which they didn’t).
Recently when I posted to this forum I finally felt I had something working when I tried what someone had posted “to really stack your coals up the back. Doing this allowed the combustion to happen, the propane sound was light and only lasted for maybe two to three minutes (unlike the fertilizer sound of the combustion engine part of the stove going nuts and threatening to overheat the back of the stove. BUT, it had been about two weeks of doing this (stacking coals high up the back and to note, yes I had a three inch coal base still in the rest of stove) when I noticed the stove slowing down. So I cleaned stove, stove had been cleaned previously at beginning of season(October) and this is the inside engine clean just to be clear. I found a lot of ashes and assume this problem due to having coals up the back. So now I am back to keeping my wood a little ways from combustion entrance, coals pushed near but not up the back wall, wood slightly spread so air moves around and not totally crisscrossed. And the result is I still get the damn problems, I still get black glass, and I still have no help from dealer or VC.
Some responses here make me wonder if my stove is missing something.
My tactic to keep house warm is to get up early and create a great coal base. I’m in and out of house during the three hour process of getting up to good coal base, add two splits in middle of stove, leave damper open for about a minute, close damper, listen to make sure things don’t get out of control, if sound gets louder and it’s been more than three minutes (yes I have tested how long it goes out of control, twenty five minutes Is the longest I have ever let that out of control sound last and I did that because everyone kept telling me it was normal! I’ll never do that again! Anyways, if not stopping being out of control I go to my second damper I installed in the pipe and close that down. I stay with the stove til it calms down and then I can open this damper about three quarters. I then close the air intake control all the way closed. This keeps my house safe, but not as warm. Finally after all this I can go to workAnd thankfully I have a dog door and my dog can get out if anything did happen.
I really wish BC would help with this situation. I needed a new stove, my last one was a ermine castings and I loved it. I really think this stove has potential to run right but something is wrong, and I have tried everything.
Good luck!
Thanks for your time responding. The second damper I put in on my vent pipe was installed when I was told I may have too much draft (I burned my previous Vermont castings for twenty years and never had a too strong draft) it helps a little but not really. It does give me the ability to really close stove but sometimes doesn’t stop the combustion in back of stove. And my wood is seasoned and stored dry with air circulation around it. Moisture meter average ready is 16, so it’s not the wood. I really wish I had not purchased this stove, the stress has taken a toll on me!Not sure if there is a draft issue here or not (too much maybe) but regardless of that VC stoves do not run well with the primary all the way closed. Also the size, MC, and species of wood an play into this. But getting back to the draft, if it's more than 0.065 (in the installation manual) it may be too much for the design of the stove (according to VC) and yes a damper may need to be employed to temper it. Also wood can be too small and/or too dry where be it wood off gass to much at one. IMO theses are not overnight stoves whereby you can after 8 hours throw wood back in and go. This no matter much you try and close it downtown extend the burn time. The glass on these stoves will not stay clean no matter what. My dealer told me not to expect the glass to stay "clean" no matter how it's run. He told me this before I bought it. However this is the Inrepid not the Dauntless. Trying to "simmer" these stoves will blacken the glass even more quickly. To keep the glass even semi-clean for a few days they need to be run fairly hot.
I just bought the Dauntless, and have had nothing but problems. I have that sound as well. Once I add wood, it starts. You can see the flames getting sucked into the back. My glass gets black as well. Had a small explosion in the stove when turning the heat down. I want to return it.Thank you. That’s a great idea. I have a thermometer on the top, but I know that’s not really giving me a good reading, so I will pick up the digital as you suggested. I definitely need piece of mind, and I haven’t had it. That noise has held me captive, unable to burn because no one could answer my question. If the manual was written with any thought, they’d have more detail. It’s got one contradiction after another.
I’ve spoken to multiple installers and other wood stove burners, but it seems it’s a common thing with VC stoves.
Most likely you had a back puff. This happens when you turn the air down too quickly and don't have a good enough draft.I just bought the Dauntless, and have had nothing but problems. I have that sound as well. Once I add wood, it starts. You can see the flames getting sucked into the back. My glass gets black as well. Had a small explosion in the stove when turning the heat down. I want to return it.
I have not, but if I don't have that torch sound, I have tons of smoke coming out the chimney. I cannot get a straight answer from the dealer or VC.Just wondering if anyone burning without a cat has measured with a digital probe while the blowtorch sound is happening. I burn without a cat, but no probe. Like newguyjoe, if I hear the blowtorch sound, I get little to no smoke, depending on the intensity of the sound. I'm just wondering if we are over firing in the combustion chamber without a cat, even though STT don't indicate any issues. Thoughts?
While I dont believe this to be 100% true, here is a direct quote from my manual.I have not, but if I don't have that torch sound, I have tons of smoke coming out the chimney. I cannot get a straight answer from the dealer or VC.
Yea inread that in the manual as well. But I'm burning 18-20% moisture and it happens all the time. I can hear it roaring from an different room. I hate it. LolWhile I dont believe this to be 100% true, here is a direct quote from my manual.
"Dry wood burns readily with a good chimney draft. But with modern stoves, wood can be too dry and too volatile. Smoke and combustible gases can ‘gas out’ from the wood quickly and densely enough to overload the combustion system. If you hear a rumbling or roaring noise (like a propane torch) from the stove, that is a sign that the stove is over-firing"
