Possibly cut the valve out on the other 2 legs far enough away so as not to damage pipe dope when you reassemble with sweat couplings after leaking leg fix. If you didn't want to consider re sweating legs or can't cut the 2 legs far enough from the valve, I'd consider shark bites
![[Hearth.com] Using Mixing Valve on Tank to Maximize Buffer Use and Pellet Boiler Runtime [Hearth.com] Using Mixing Valve on Tank to Maximize Buffer Use and Pellet Boiler Runtime](https://www.hearth.com/talk/data/attachments/177/177257-6a4d318a80fd631873c1925063d0fb08.jpg?hash=V06Vk8JxIr)
![[Hearth.com] Using Mixing Valve on Tank to Maximize Buffer Use and Pellet Boiler Runtime [Hearth.com] Using Mixing Valve on Tank to Maximize Buffer Use and Pellet Boiler Runtime](https://www.hearth.com/talk/data/attachments/177/177412-cfd58fbfdc7846da5e2893d38880e2e2.jpg?hash=NwWhyZqa3j)
![[Hearth.com] Using Mixing Valve on Tank to Maximize Buffer Use and Pellet Boiler Runtime [Hearth.com] Using Mixing Valve on Tank to Maximize Buffer Use and Pellet Boiler Runtime](https://www.hearth.com/talk/data/attachments/177/177413-effa521f31de49034cf13d1e47894b38.jpg?hash=8eCMLgABqY)
![[Hearth.com] Using Mixing Valve on Tank to Maximize Buffer Use and Pellet Boiler Runtime [Hearth.com] Using Mixing Valve on Tank to Maximize Buffer Use and Pellet Boiler Runtime](https://www.hearth.com/talk/data/attachments/177/177536-30cb899bc769831eff2a8224426a2ab4.jpg?hash=f6dxhlPmEe)
![[Hearth.com] Using Mixing Valve on Tank to Maximize Buffer Use and Pellet Boiler Runtime [Hearth.com] Using Mixing Valve on Tank to Maximize Buffer Use and Pellet Boiler Runtime](https://www.hearth.com/talk/data/attachments/177/177537-3a7cc03c699094aa1db40347ad0d933f.jpg?hash=qDZFmmfIO-)
