Howdy,
I'm going to be build a new garage/workshop that will also house my IWB.
So my question is can you drive over buries water lines(I plan on using PEX) ? The lines would sometimes have loads of upwards of 100k lbs crossing them from time to time. The grain semi's load is legal at 80K lbs, but if the corn is running wet you can easily go over weight. I was thinking about installing concrete culverts or maybe pouring a "U" shaped footer to put the lines in and then putting a reinforced concrete lid on the "U" footer. Just throwing out ideas. The garage and house will be split by the driveway and there really isn't a better place to put the building on the lot due to the current layout of buildings, septic system and the pond.
Has/ Does anyone out there drive over their buried lines? Have you had any problems?
If I can't drive on the lines I'll have to put the IWB in the house,which I really don't want to do, and I'll also have to find another form of heat for the garage.
Any help would be much appreciated. Thank you
