I get more action from the stove.I tried to explain the tunnel of love technique to my wife last night.....she said told me she is worried I am going to leave her for the wood stove.
Small firebox. If I rake them much at all they end up on the floor.Don't rake them so far forward?
Similar though Tunnel of Love is awaiting trademark for the differences.
So that was one time that your wood was too dry?I dunno. I seem to remember trying that little romantic boat ride many times at the fair as a teenager (with great expectations), but it never did seem to work out for me the way I'd hoped.
My stove isn't big enough to waste that space on the sleepers, but I've laid an E/W load directly on the coals after making a trough in them. But I usually just try for the long burn from front to back, so I want to keep the flame up front at the beginning.T o L works even in an E/W burn stove. Lay 2 short N/S sleepers about 6" apart with hot coals between them, then put the E/W splits on top.
Similar though Tunnel of Love is awaiting trademark for the differences. T o L works even in an E/W burn stove. Lay 2 short N/S sleepers about 6" apart with hot coals between them, then put the E/W splits on top.
Not sure. I've never experienced a stove running too hot that didn't have to do with an error on my part (air controls open to far/long, door cracked too long) or a strong draft (which I suspect is the issue with the Defiant's temp climb as it moves through the burn cycle).Could this burn the wood faster, more air flowing under the loaded splits? May even add to why our EPA stoves overfire. Just wondering.
I guess I'm missing the point. In one thread, folks are suggesting every possible way to slow down the burn. "Don't put your splits right on the hot coals, rake them forward and throw the big splits low in the back. Pack the firebox tight, and do a top-down burn." Here you guys are outline a method which is sure to make the load burn much faster. Do I need to go back to school?
I do it as I do not have a problem with stoves running away from me. It speeds up the reload time, which means less time I am tending to a stove.I just do this when i want more fast heat.
If I burn E/W with a full load, the stove will give me 9-10 hours of heat whether I use the tunnel or not. If I want less heat, I just use less wood for this stove.
I have found out this year that the mag loves burning E/W it makes for some very nice dancing blue flames.
Corey you should post a pic of your stove, with the secondaries kickin.
I thought about uploading a video when the weather cools back off did not even have a fire today.
