Dear Lost in Lowell....ha, sounded like this should be some kind of intro to a Dear Abby column or something.
As luck would have it I happen to be in Grand Rapids and I happen to run an EKO40 of similar vintage to yours. And it also happens that I enjoy beer. It's entirely possible that I could be convinced to swing over to Lowell for some boiler fun.
But first....your boiler is surely big enough to heat your house. I heat quite a bit more than 2200 with mine (it is 40KW, not 40k btu). Actual output is just north of 100,000btu/hr. Your experience with H2Oasis is consistent with others I've talked to. Step one - stop calling them. And forget about going there to buy parts. They want your OWB business and that's about it.
When you say your boiler is outside, it is in a shed or garage or something, right?
Here is some helpful info you may want to peruse.
http://www.newhorizoncorp.com/PDF/ekomanual.pdf
http://www.newhorizoncorp.com/wp-content/uploads/2011/06/RK-2001UA-ENG12.pdf
Those two documents will go a long way toward helping you understand your system. Let me know your thoughts. I may be able to get out your way this weekend if you can survive that long. As stated above stop screwing around with those plastic barrels. That's a complete waste of your heat output.
