Ahh now I see, it was so dark it looked like the surround above. Is that galvanized pipe?
Pretty sure it is, also see that begreen mentioned it as well, that is a no go for wood burning exhaust.
Cleaning that setup is going to be a royal pain in the arse, if there is anyway to get a top to bottom 6" stainless steel liner down that chimney (insulated prefered) then I would do it.
I would call a local stove dealer and see if they can get you a piece long enough of stainless to do that direct connect properly at a minimum.
I have had good success with Bylers up in Dover, not sure how close they are to you.
Not to rain on your parade even more but I would also double check the clearance to combustibles to that mantle and make sure you are ok.
I would check out pages 14-16 of the manual of that stove. They are specific for a reason when they say stainless steel for the liner, and that wood mantle looks to be closer than the required 10" clearance to the sides.
(broken link removed to http://www.century-heating.com/upload/documents/manuels/45399A_07-07-2014.pdf)
Just looking out for your best interests, we want people to burn safe.
Insurance company is going to go by that user manual if anything happens. Btw you have called them and let them know you have added an insert and need to add that to the policy right?
Easy soldier. We can get you through this.I told my agent. Jeez, I have some major work to do. I should just sell this damn thing and go back to electric heat lol. I'll use the firewood for outside fires.
Bite the bullet, get the chimney cleaned first, then install a proper 6" stainless steel liner up to the chimney top. You will find the stove operates better and will be much easier to clean. But most importantly it will be safer as well. Yes, it's another cost, but this is a one time investment in safety and performance that will pay back many times over the years. Note, there is no conflict about what type of metal to use. Stainless steel is required.
The mantel may need some heat shielding if it doesn't meet clearances. That is possible with a bit of sheetmetal painted black attached to inner perimeter of the fireplace opening so that it projects about an inch past the mantel trim.
You are better than half way there, just a few things to correct. Get rid of the galvanized pipe. Get a liner in that chimney (after a proper sweeping) and check your clearances. Even if the clearances to the mantle are a bit shy, there are easy ways to remedy that (heat shield).
Sounds like a plan. We want you safe, warm and happy.
You didn't invent any of these issues. We have seen them before. Our main concern is a safe install for you and yours along with a little friendly banter if warranted (and sometimes even when its not). You'll get there. Stick around and follow the collective wisdom of the likes of BG, BroB and the many others.
I'm just here to poke a stick at people when they start to nod off.![]()
Yes - I would think that most would consider that on the high side of acceptable. My stove has only hit that mark a small handful of times.That seems extremely high right?
Some folks do some dangerous things. Dump a load of construction scraps and pallet wood on a hot bed of coals and you will see a serious conflagration.
