I like it too!I really think Coal Reaper's idea might be the ideal solution. In fact, I am curious as to why AHS didn't just do it that way. It's significantly cheaper than the timer
http://www1.mscdirect.com/CGI/NNSRIT2?PMPXNO=23974495&PMTERM=77981934
this here. but without knowing the schematics of the WG i would think you will need another NC relay to cut the power going to this timer when the WG is on due to call for heat. then when WG shuts down the NC relay will close and start the timer all over again.
Here's the SESTOS B2E, same idea, just search for digital timer on ebay and it'll come up. Has a configurable 'reset' input to hold off the timing cycle until woodgun shuts down, but still going to need a spare set of contacts to gate the call to heat signal.
http://sestos-hk.com/english/download/B2E-en.pdf
Too much bling! It seems that you WGers are more about KISS than any of the other boiler operators. Dont stray from that!
DIGITAL things on my Wood Gun?!?!?! Unacceptable. What do you think this is, a BMW?
LOL
you can upgrade a woodgun all you want...
but it will never be a bmw
I'm not saying this to bash Wood Gun but I think you guys are confusing simple with primitive. My EKO is simple. Two boxes stacked atop one another with a hole between them. No motorized damper, several fewer lineal feet of door gasket, burns up, burns down, less heat radiation due to better insulation and simple designs on the interior. Take another look with an open mind and you'll find more. I think you'll find that Wood Gun is much more complex with more things that can go wrong.
I hope the guys that I have been conversing with on here get a long life out of their Guns. My opinions are obviously affected by my past experiences.
That very well may be so maple. Smokeless heat is also on my list of places to visit to help me decide what boiler is right for me.Sorry, the KISS line starts behind me.![]()
I ran mine for 9 years before I disposed of it. One advantage the present owners have is this site. There was nothing like this when I had mine. I was all alone out there with with the problems and had to diagnose and overcome them on my own.How long has everybody had theirs?
For me it is less about things to "go wrong" and more about "parts availability".
I like that all of the controls and gaskets are easy to find and readily available from many local and internet suppliers. I don't have to worry about a control box that is made specifically for my wood boiler in another continent, imported by one source in the US.
Ahona sells a made in the USA controller that is a direct replacement.
(broken link removed to http://www.ahona.com/products.html)
Parts was why I initially wanted the woodgun but I figured for about the cost of a cycle timer I could have a spare rk2001 on the shelf. And it's not like i couldnt convert my boiler to run off aquastats and cycle timers if I wanted. Others have done it.
And I'd say the fine tuning stickies are pretty similar to this thread, users figuring out how to get their boilers to run smooth. Though it didn't take quite as long!
4th year with my boiler, going on 17+ cords burned thus far. Replaced door gasket after year 1(still looks good today), made my own flap for the air intake box after year 2.....that's it for "repairs".
No doubt this forum and the internet as a whole is a great help no matter what brand wood burner you own. I can appreciate the situations Fred and others may have had in the past without these resources. Using a little help from my friends I have been able to correct a few initial issues I had with the WG and I know many others have done the same regardless of the unit they run. For some an "issue" is a big deal and for others it is not. As an example, it has been printed in this forum that the creosote build up in the fresh air intake box was an issue...seems a big issue at that. To me the creosote is not an issue at all, I use the tool AHS supplies to push any build up in the intake tube back into the firebox during my weekly cleaning...simple and quick.
I was surprised that AHS did not supply my boiler with the rope type gasket and that the flap was not a better build quality but those issues were resolved easily and fairly cheaply. Other than those I don't see any signs of what I would consider premature wear, perhaps the next few years will show otherwise. YMMV.
For me it was alot of bad things that added up. You have done well with your center bricks. Your mention brought to mind one thing that rubbed me wrong. There were years when I replaced the bricks every year. At that time in the mid 80s the cost of the bricks was equal to three to four hundred gallons of fuel oil. The bricks are cheaper now and you know where oil went.
