Who has a Wood Gun and storage?
You. LOL
I hear ya. The other thing is that since we have lived with oil for 10 years we have gotten used to auto thermostats. House was set on 64 and would go down to 60 at night. Wife always complained about the house be cold. I think she reset the thermostats to 67 and 62 for the overnight. If it can get me dialed in I going to go to 70 and throw caution to the wind. I think I may have her purge it every hour during the day also just to turn the fan on and stoke the coals.It would seem to me that you would want it to cycle on once an hour for a few minutes. Then you would cover even more territory of mild weather. Turning the temperature of the house up does seem like the bass ackwards thing to do to me. Burn more wood and have your house warmer than you need to.? Just sayin.
I'm with Gasifier. Even at two hours I think you're going to come home to a cold boiler in this kind of weather. 6 minutes every 80 works for me and I would ask others here with a cycle timer to give you their settings too. Having to send away for a chip is a bit of a pain so you'll want to get it right the first time if you can. Or maybe Darren can send you a couple different choices you can experiment with and send back the ones that don't work for you? Hmmmm....Wonder exactly what these "chips" are. Perhaps you can buy blanks and program them yourself so you can have one for the mild weather and one for the colder months?
You. LOL
Well this needs to change my friends. Even my little old 400 gallons of buffer really helps. All year round.Me personally, I'll never sell my gremlins.
stoke the coals
If you mean stir the coals, I suggest that you just leave them as they sit. If there is a coal glowing in there it is most likely staying alive because of the insulation being provided by the surrounding coals (banking). Stirring may just bring that one coal to the top and burn out or not maintain enough heat to stay alive. Allowing a small amount of air in the firebox periodically should work. Even though most folks believe the burn chamber is totally sealed at idle, the fact that wood gasses dissipate from the firebox within minutes after shutdown proves that there is some flow through the box unless you think the wood re-absorbs the gasses.
Meh. So far I see no reason to add storage, even through these warm periods. Spending all the money on storage would just push my payback further out.
ac
Turn on the purge timer within 5 or 10 minutes after shutdown BOOM. Wait 15 or 20 minutes turn on purge timer and no BOOM. How come?What makes you think the gasses dissipate? The lack of dissipation is what causes puff backs when the boiler kicks back on sometimes.
When I first installed my boiler, I had a bunch of leaks at the chimney connector. This caused me to shut the boiler down in a very smokey state. I pulled the chimney connector off to re-seal all of the joints. I was expecting a serious nightmare of smoke from the firebox. Amazingly, NOTHING came out of the cyclone. When I opened the wood chamber door, I got a major face full. The WG seals up quite well. The only way for gasses in the wood chamber to "get out" is to travel DOWN. That doesn't happen well without a forced draft.
ac
Pfffff. Payback smayback. Some day I am going to have about 1200 gallons of storage. And it will be worth it.
I've seen that statement more than once in your posts but you continue to challenge statements made by others about the workings of the boiler.Frankly, I couldn't care less exactly how this boiler works. I'm running with no storage and have a warm house with very little human interaction
And yet you still haven't figured out how to turn fire on and off? :-/Take what you will. There are about 1/2 dozen actual current WG owners actively posting on this thread. All working together to get the boilers operating as easily and reliably as possible.
Damn laws of physics... I just can't go to bed until you admit idleing = off, cycling or as the super cool frohlingers say slumbering.
Here we go again. These WG debates always end up like this. Can't we all just play nice in the sandbox.
And while we are playing nice, we all need to agree that the WG turns off and on a fire.
