bdud,I use a Nyle Geyser water heat pump connected to a Caleffi 80 gallon water tank which supplies all the hot water requirements for our 5 adult house when not using the pellet boiler. No one has noticed the water not being hot. The water pressure with the more consistent temps with 2 showers running at the same time, is so much better than our old indirect coil in the oil boiler. A plus is also a cooler, dryer basement and the water condensate I pump out to a little herb garden growing outside.
I've just installed a Nyletherm. You don't have to worry about the condensate freezing when you pump it outside because you only use it in the summer? Do you have a recommendation on a pump? Thanks.
Also, another advantage of an add-on hpwh is that the total installation with tank can be shorter. The integrated units are pretty tall. However, the add-on does take up a little floor space.
