Ashful
There are ones that can keep up. But that doesn't mean they are great heaters
Burn time issues?
Eh, cook stoves just don't make good heaters, even if they are huge. Big ones like the Heco 520 advertise long burn times, but I doubt it.Burn time issues?
Stoves of the non cook stove variety can be cooked on also. The PE Alderlea series (T4,T5,T6) even has swing away trivets to help control the heat. Flat topped stoves give you more surface area, but I've cooked just fine on step top stoves. I'm not sure I'd try to cook on a stone stove for fear of staining it, but I'm sure it's possible.
It's true, you could cook on a regular wood stove, but it would be like trying to heat a house with a cook stoveWe had a long power outage and I did make coffee on our wood stove once. I think I've also heated up cans of spaghetti o's while my wife was at work.
On winter mornings I put a kettle on the stove to heat up the water for tea and coffee. We've cooked on it just for fun, but I put in a propane cooktop as soon as we moved into the place. Extended outages are not rare here and that has us covered. What the Alderlea cook top is great for is slow cooking in a crock pot. The swing-out trivets afford a great range of temperature for cooking. My wife also swings open the trivets and uses them for rising dough.It's true, you could cook on a regular wood stove, but it would be like trying to heat a house with a cook stoveWe had a long power outage and I did make coffee on our wood stove once. I think I've also heated up cans of spaghetti o's while my wife was at work.
I used to do this, too. But then I bought a cheap 8kW generator, which I can back-feed to the whole house, and fire up my microwave or electric range top. Heck, even cooking on the gas or charcoal grills outside is more expedient and convenient than cooking on my Blaze Kings.
Or bust out the gasoline powered Coleman cook stove. It’s good practice to use your alternative cooking tools.
The rv has a propane cooktop and oven too.
Really, the last thing I would cook on would be the wood stove.
I also have a propane grill, but generally if the power is out I'm not going to want to be outside to use it. The RV is a great idea though! Mine is in NC right now, hopefully coming up here next year.
I lived in mine for two years with my wife and three dogs. It's certainly not ready right now, most of the furniture has been removed and there's no bathroom. Once we build a barn I'll be able to finish working on it. Like your RV ours has all propane.If you’re a disaster preparedness type guy, a self contained rv is actually a pretty good way to go. Mines fully loaded, kept warm and ready in a separate building.
You can be sure most of us would not be cooking on the wood stove in the summer. Disaster preparedness means different things in different areas. Many RVs do not have good insulation and winterized water systems. That could be a challenge in Maine winters, but better than nothing. Highbeam lives in the shadow of a large volcano and pyroclastic flow zone. Having a packed and ready getaway vehicle is a good plan, though there would probably be plenty of warning if Rainier decided to wake up. I'm not a prepper, but both of us live in earthquake country. It could be weeks before we see recovery efforts in our rural communities in the event of a big one, so a reasonable self-sufficiency plan is a good thing.I lived in mine for two years with my wife and three dogs. It's certainly not ready right now, most of the furniture has been removed and there's no bathroom. Once we build a barn I'll be able to finish working on it. Like your RV ours has all propane.
Nice choice. That should work fine.Think I'm going to get the Sirocco
Many mid range RVs, and certainly mine, are called 4 season trailers with insulated and heated underbellies and insulation better than many homes. People go skiing and hunting in them so the market responded by making them winter capable. If you can keep the furnace running then your systems are all up. Certainly in above zero climates anyway. The new ones all seem to carry over 50 gallons of water too.
Our minimum standard is 14 days with no outside help. Think power outage as a more likely event. Then if my house burns down I have the second home. Finally, being able to hitch up and leave is a decent option but we’re more “shelter in place” type people.
That's going to stick out a good 5 or 6 foot above the roof line for sure.
