Some utube guy who builds his own stoves mentioned that he puts stainless mesh in his flue. Says it glows and burns off gasses that make it past the baffle. Sounds reasonable to me. What am I missing?
I have similar in the 8" Pipe outside to prevent birds getting into the Pellet Stove. Stupid things. One got in last year. But having it there it might clog up and prevent good airflow. Easy to clean?
In the flue? I agree with the flyash buildup and reduced draft concerns (and how would you get it in and out of the flue for cleaning)? Not that it's not possible just because I don't know, but still... must be relatively low to soak up enough heat to glow enough to ignite some forgotten volatiles?
Woodstock used Iconel screens inside the firebox of early Progress Stoves to catch flyash before it clogged the Cat. It was supposed to burn up the flyash (kind of like a pre-cat) but it ended up clogging. The Iconel is super temperature resistant but after a season's use it turned brittle and crumbled. They no longer install that screen in new stoves.
