Great to see a few owners surfacing since reports have been few and far between. I'd be interested in hearing the sq.ft. that folks are heating, burn times, and how the stove runs. What's your chimney setup? Do you find it easy to control the output of the stove? (I've never run tube stoves, but what I read here is that it's critical on a fresh load to be cutting the air before too much wood gets gassing, so you can control output and burn length.)
for anyone else who doesn't think it's ok for the stove to smoke when you open the door, I welcome your suggestion. Like I said, my last stove didn't smoke, and I heated the house with it for 12 years. Thanks
This stove is probably a little different than what you had before. The box is wide and shallow, and with no bypass and the big front door, smoke spillage is more likely. But the big-window view is worth making allowances for, IMO.
![Cool :cool: :cool:](/talk/styles/default/xenforo/smileys/shade_smile.gif)
With 20' of stack, you should have good draft. If you
must use the front door, try closing off all other air (side door and air control) to force the draft to pull into the front door stronger. Like others posters, I don't need to poke the fire and don't use the front door, just side-load it, close it, and work the air controls and cat bypass, then cruise until it's time to reload. If your wood has been split (not too huge) and stacked for a couple years (longer for the Oak and Hickory you have,) it will start right up when loaded on a coal bed, you don't have to coax it to burn. You may need some bigger splits to control the burn in your stove, but if you're leaving round logs unsplit, they take
really long to dry (maybe decades for Oak.)
![lol ;lol ;lol](/talk/styles/default/xenforo/smileys/lol.gif)
Get way ahead on your wood supply, and the payoff is huge...burning wood becomes a joy instead of a chore. I tried to burn wet Red Oak for many years until I came here and got dry-wood religion...never going back. Now I'm burning 3-yr. Oak and Hickory, and lovin' it!
![shade smirk >> >>](/talk/styles/default/xenforo/smileys/shade_smirk.gif)
