No offense taken.. It's just what I have down and around the property.. I don't like to leave it on the ground as the carpenter ants here nest in it.. I agree it does burn faaaaaaaast... Super fast when it in the 10% moisture range. .Didn't mean to be mean. Given that NYLuke said his wood was dry, I was thinking more of how fast it burns, etc.
Where is that coming from? A warm chimney absolutely drafts better than a cold one. In the most general terms, cool gases sink, hot gases rise. The differential is what powers draft. we get many people a month at this time of the year that have to warm up their flue before it will draft properly.The draft is a big deal. Someone mentioned earlier that a warm chimney drafts better? I don't think so. The colder the better. Hopefully your new pipe situations has helped with that.
Assuming NY Luke is in NY like me. We have pine everywhere but it’s at the bottom of food chain. Anyone that sells firewood here does not include pine.Pine is ok as long as it is well seasoned. That's all that some people burn in parts of the country. Likewise for birch. The problem with pine is that it can be burned almost green because of the pitch content, but pine, or any wood that is poorly seasoned is a recipe for creosote and the potential of a chimney fire.
Sorry about the chimney temp confusion. What I meant was that the outside temp should be cold. Our chimney is along the outside wall of our home and is about 20-22 ft. …drafts beautifully. We also have a 6” liner which is why we went with the Manchester
Hello NYLuke. I read your entire saga with the Hearthstone stove right after I posted my own with the Hearthstone Heritage today. You were really thorough in your answers and I found them helpful. But I do think the Hearthstone stove is a bit of a touchy creature. I like it, not saying I don't, but who knew I was going to be taking up Stove Lessons in my old age? My own wood burning experience was on the farm in Oneida County back in the 70's. It was simple, you put in the wood, adjusted the pipe damper and the air intake (on our 2 Ashleys) and let it go. I guess the flue temps were hot as a lot of air went up and this kept the chimney's clean. I cleaned mine, like all my old timer neighbors who'd been heating with wood since they got the land from the Iroquois, once a year. Dropped a chain down on a rope. Simple. Probably we used the same chain on the tractor wheels in the snow.Hey guys..
I've been meaning to drop by and say hello/give an update.
Things are good. Fully recovered from the hernia operation.. Clean bill of health.. Will be splitting a whole bunch of oak (that I mentioned earlier) this weekend. Since it was dead standing stuff, moisture content is in the 30-35% range so it should be good for next year.
Stove is good.. not great.. Just good.. 45's definitely helped with draft and startup.
Now that colder weather is here. I can definitely say that the house is not as warm as it was with the Federal.
Furnace has begun to run considerably to maintain the temp in the home. Its just not a big heater like the Federal was.
I'm a little disappointed there.
As for the cat, engaged, it sips wood.. However heat output in these temperatures is not what I need.. I've been mostly burning the past week with the cat disengaged to increase the BTU's and get what I can out of it. Even with cat disengaged, wood usage is much less than the Federal. External temp on the stove stays around 400-425max and that is on the side right next to cat probe. Since I figured out that the cat temp probe was off and stopped engaging the cat based on it, I havent had any more fires in the stovepipe. Now I engage only when external temp next to cat is 325+ and have no issues.
However as another member recommended, the fly ash needs to be cleaned every two weeks or it impacts performance. Doesnt take long to do it but I have to let the fire go out and I'm not a fan of that in the colder weather.
Probably the biggest complaint I have is that since I went to my harder woods (Maple, birch and hickory) is that after a day of continuous burning, I end up with a full firebox of coals that I need to burn down and while they are burning down, heat output is diminished. From what I've been reading it seems to be normal for the stove and the amount of coals is definitely magnified if the cat is engaged. , but I think it's a real pain in the ass. Thoughts?
So I'm still learning, but I think I have it figured out pretty well. If I had to give it a grade, I think that from Oct thru December, it would get an A- due to the cat maintenance/cleaning, Jan and Feb are looking to likely be a little painful. However I would imagine Mar to May will be like Oct - Dec and that will be just fine. All in all the family is enjoying the even, longer-lasting warmth/heat of the soapstone over that of the Federal, but with temps in the single digits tonight, Im definitely longing for that 28" firebox lololol..
I hear all the chatter regarding burning pine, but I've been burning dry white pine without issue in the Federal for 15+ years and purchasing a few cords of ash/elm/maple, which is what a lot of the vendors here are selling, at 250-300 a cord just doesn't seem to make sense. Personally, I burn wood for two reasons. One, I enjoy the outdoors and the cutting and splitting keeps me active. The second is the "free" heat. If I'm going to spend $900 a season on firewood, the way I see it I might well spend $1500 and turn up the furnace..![]()
Thanks again for all the help and advice,. Hope you are all well and staying warm.
Hi Joe,Hello NYLuke. I read your entire saga with the Hearthstone stove right after I posted my own with the Hearthstone Heritage today. You were really thorough in your answers and I found them helpful. But I do think the Hearthstone stove is a bit of a touchy creature. I like it, not saying I don't, but who knew I was going to be taking up Stove Lessons in my old age? My own wood burning experience was on the farm in Oneida County back in the 70's. It was simple, you put in the wood, adjusted the pipe damper and the air intake (on our 2 Ashleys) and let it go. I guess the flue temps were hot as a lot of air went up and this kept the chimney's clean. I cleaned mine, like all my old timer neighbors who'd been heating with wood since they got the land from the Iroquois, once a year. Dropped a chain down on a rope. Simple. Probably we used the same chain on the tractor wheels in the snow.
In the course of installing my Hearthstone I had to install a 6" SS liner in my 8 x 12 clay tile flue. Never having done this before I had a local guy do it. I was baffled as to how I would be able to join the liner to the stove pipe and the snout Tee and the end cap. My own installation was even more complex as I was venting out the back, rather than out the top as you did and because my stove is only 3" from the wall behind it. Because you expressed concern about having to break your stone work and all, I thought I'd send you some info.
You should run all that I say by a supplier or an installer, I share it only to give you an idea. My own liner came from NE Chimney Supply in Williston VT. They make it all there and their prices are very competitive. You should go to their site and see what a Snout-Tee looks like. Anyway, if your 8" is fairly straight you should be able to get a 6" down it. The tee will already be on the pipe as they lower it from the top. You probably want the cap to be installed securely as well, before lowering it, as you will never get to access it again. This is all doable as the leg of the Snout-Tee, the right angle, is removed. When the tee is lined up with your opening where your thimble is, the leg is inserted and via a clever use of SS strap it is attached on the inside by reaching in with a socket on a very long extension. No need to touch the outside of the tee, which would be impossible anyway. You may lose the thimble, but it will not matter as you will attach your 45 to the leg of the Tee that will be sticking out of your wall (or an extension thereof if the leg is not long enough). Then you can mortar it in, or attach a metal trim collar, as your taste and the dimensions dictate. (By the way, be sure your snout is attached and you are satisfied with the angle (that is, it is at a perfect 90 degrees, before you proceed to finishing on the roof, as once you pack in the insulation up there the liner will not longer be movable and your connnection to your stove will always be crooked).
The CAP on the Tee.
The reason you want a cap (you asked about this) is to make the new liner totally airtight, as it is assumed is your existing 8" tile liner. You don't want to lose draft to a leak and you certainly don't want to lose creosote to one either! After the tee is properly lined up you stuff the space between the 8 and the 6 with insulation to keep cold air from falling down. Then you install a top to bridge the distance between the 8" and the new 6" liners and seal it with silicon. All this is SS. You finish it with a SS rain cap with a bird screen. This is the only item you need to remove when doing a sweep, if you sweep from the top.
When you clean your chimney you will disconnect at the tee, or the thimble, and vac out the soot that fell as you brushed. I suppose you could also brush from below as long as you don't damage the rain cap up on the roof. If it all goes well, you should not have to damage any of your stone work inside the house, or on the roof for that matter.
But hopefully you will have to do none of this as you will get the 8" pipe to work. By the way, if the things you are trying do not work, it occurs to me that perhaps you might consider using 6 inch pipe from the 6" connector on your stove up to the thimble. This idea is based on the notion of fireplace geometry, where we built a throat just behind the lintel. The throat caused the smoke to speed up as it entered the smoke chamber above (in the wall behind the mantle) where it would expand and help repel heavy cold air that might be falling down the chimney. That extra speed might help lift the cold air column that sits in the 8" flue. Just an idea, I've never done it, but it might be bounced off a few others to see what they think. (I used to build Rumford fireplaces, both in CA and in Camden NY).
Last thing. I too was stunned when I called Hearthstone and was curtly cut-off and sent to my supplier. Like my supplier, a large company in Indiana that sells stuff, was going to know how to field a tech question about an installation. I would never have bought had I known how they are over there at Hearthstone. Most unVermont-like, that's for sure.
Good luck
Hi Bill,Hi Luke and all.
Thanks for all the updates - very interesting. I still wonder if the cat thermo had moved from it's original, correct spot - that little dial is easy to move. You might want to call Peter at The Chimney Sweep Shop in Barre, VT. He's a font of information and has a great relationship with Hearthstone - and he's been around a loooong time.
I've had a few years with our Castleton II - the coal situation does require a bit of work. I remove ash every morning (in a nice warm, not hot stove) and that helps keep the air moving. I find the need to ensure some air around the pieces of wood - just a bit. If I pack a few logs tight together, it takes a while before they all catch and then burn good, so I give them a little air - not a lot. I keep the stove humming around 400 - 475, cats engaged with enough time to burn off and then damp the primary as needed - sometimes in the cold weather not at all, sometimes just under 1/2 open. The cats - when I'm getting the ash out - I can make a pile of the hot coals and I cover them with my ash bucket lid. The stones are still nice and warm but with the door open, I can reach in with gloves, sometimes no gloves, remove the pin and first piece of baffle. Vacuum out the cats, give the window a little cleaning (using first some fine ash on a damp paper towel, finishe with some stove glass cleaner, and I'm good for weeks on both the cat and the window - takes about 10 minutes. The window never really gets bad anyway - I just like it clean.
Stay with it Luke - you'll find what works best for you and get in a great rhythm.
From the "for what it's worth" department.
Bill
That has the potential to do some major damage to the stove base. Instead open the front door a bit, use more good dry kindling, and/or try a good firestarter like a chunk of a SuperCedar. A good source of dry kindling is a cabinetry and trim wood shop. They create a lot of scrap material, just be sure it is unfinished.I'll check my theory but it seems to happen when I open the bottom ash pan to give it a little more air on a cold start.. Even with the change in the stove pipe I still have do that on a cold start to aid it in getting going. Draft is better but it still has a hard time with a cold start without it.
