Well I just got done working on a 056 magnum 2 and ran it. All I gotta say is she's got some power. I'm only running a 20in bar and I'm ripping blocks down. She's a beast for sure. I just may have to add one to my collection.
I love running a small bar on a huge saw. My 395xp is set up for milling and I have a 16" bar on it. Rips small logs into 4x4's with some speed! I bump up to the "long" 24" bar for larger logs. Still have the original 28" bar and can go up to whatever size I need, but low profile ripping chain tops out at 24" and I like the small kerf. The Chinese 3/8 lp ripping chain I have doesn't hold up to the 24" bar so I had to spring for the expensive Stihl 63PMX, which is what the Chinese made chain is copying. To be fair, that chain might hold up to 24" with a less powerful saw, but that's way too slow for me. I bet that 056 would make a decent mill saw.Well I just got done working on a 056 magnum 2 and ran it. All I gotta say is she's got some power. I'm only running a 20in bar and I'm ripping blocks down. She's a beast for sure. I just may have to add one to my collection.
A few weeks ago I found a 084 for $150. If it wasn't 3 hours away and snowing, it would be sitting on my bench. I like the 056 because of its style. I have a 031av and a 041av. So it would match the style. It's not something I would use all the time but one of those, let me go grab my saw cool factors. And occasionally at work we come across some big stuff. I notice alot of people on here one across fir. Is it hard or soft wood? We have lot of oak, hickory, ash where we are and some soft wood aswell.I can’t remember who modified the last 56 I had but it was a dandy job. I’m not that knowledgeable about the subject but it seemed like they gained more from stock than the 66’s did back then. I had a resi tree service on the weekends and we had a modified 64 that really didn’t cut the mustard for old growth but it was extremely peppy for chunking down fir and nice and light compared to the 56
Yeah I noticed the 056 sure like the gas too. I was in the process of tuning and it seemed like it went through it pretty fast. The second tank was better and the saw really came to life when I got it tuned. Of and when I get an 056, I will probably let run a 28" bar on it so it should do pretty good.Fir is a softwood. It changes when it matures at about 100 years and we called the younger red fir and the old yellow fir because it lost any red in the heartwood. It becomes very resilient to weather as well. I’ve actually seen old 100+ cabins roofed with it and still dry and third growth stumps nearly rotted away next to an old growth stump that would still have sound wood inside. I ran an 084 off and on but it required a steady stand of large old growth on decent ground ( not steep) to be profitable as they were gas pigs. I actually ran a 32” bar on one in a steady stand with an average of 32-36 dbh and it just didn’t pay which was I found odd but whatever worked the best won
At least Husky model numbers will loosely tell you the displacement of the saw. Stihl 056? What does that even mean 🤣 At least my 395xp makes some sense, 3 = third generation, 95 = rough displacement, and xp = as we all know pro saw. My 460 "rancher" is a fourth gen "landowner" 60 cc saw.Buying new saws kinda looses its fizz when they become a daily grind. I changed to husky from stihl after about 15 years and that was kinda cool for a while. Still have trouble with the model #’s on the huskies and refused to work on them other than normal maintenance lol. Joys of getting older and more financially stable.
I got away from stihl because the seemed to always take more pulls to get started. My ms441 was like that from new and I took it back to the dealer. They put a new carb on it and it didn't seem to make any difference. That was while it was never warranty. My ms 211 was the sam way. All the saws I have now all start within 4 to 5 pulls. My little 421 dolmar always start within 2 pulls. And my opinion, I think the husky, dolmar, jonsered and echo are easier to work on. That just might be me though. I still like the old schoolBuying new saws kinda looses its fizz when they become a daily grind. I changed to husky from stihl after about 15 years and that was kinda cool for a while. Still have trouble with the model #’s on the huskies and refused to work on them other than normal maintenance lol. Joys of getting older and more financially stable.
Go for it. Add an aux oiler if the OEM pump doesn't put out enough.How do you guys think the 056 magnum 2 would do on an alaskan mill? I sawed a piece for a bench today with the jonsered 2172 and 24" bar and it did descent. The slab was about 18" wide.
Special occasions. Lol. Every once in a while I come across some big wood to cut and also I may get a alskan mill sometime.I like my 395xp, but it has only performed two or three cross cuts in its whole life. I had to get my pinched 460 out of tree once, and I used it to shorten some 18" firewood to 16" and everything else has been on the mill. What are you using this beast for?
