drstorm
Burning Hunk
Go to a Tractor Supply store and pick up a few packs of the compressed saw dust bricks.Throw one in and see if its any different.They sell for 3.99 a pack of 3, twenty pounds a pack.
Thanks for the replies. I wouldn't have thought that brush would retain moisture like that from just rain. I'm certain the oak I have isn't really ready to burn but the cherry seems good I just still dont get those high temps on the stovetop you guys are talking about. I can get it that hot if i feed it small splits but that isn't very useful to me for a longer burn Nd it will take me a while to get it to climb to 600. Could the 45 be killing my draft that much?(yes it 45s and then goes straight out the roof) It seems like theres good airflow but the fire itself is telling a different story. As a side note I've also noticed I get much worse performance if the box is loaded up more than if I just have 3 splits in it say
It heats the house I'm just concerned about the cleanliness of the burn and I'm not sure if I'm just obsessing
Still sounds like less than ideal firewood.
My first year, I thought "I've got seasoned firewood, I'll be fine." *smirk* Clogged the chimney in the PE with in 3 months *good bye smirk*
How long has it been split, etc?
I stacked it in late September but nothing looked freshly split so I'm assuming the guy who delivered it was storing it split not in rounds. I had no choice but to get a delivery come September. It's just the way things worked out for me this year. I bought 6 cords though and I've not been running through it like I thought I would so I should have some good firewood for next year
Sounds like a typical case of first year syndrome
Do yourself a HUGE favor, and order another 6 NOW (or what ever you can swing), you won't regret it !
That's interesting I didnt know that that could help. The days that I have been struggling with the fire are definitely overcast rainy days. My house is well insulated and very air tight. It is a split level as you described with the stove on the mid level off to the right side of the house and the left side of the house which is the other two levels is higher than itSeems like I recall several of these 'low draft' threads but they typically revolve around basement installs, split level, or two-story houses with a 'bump out' containing the stove. What they typically have in common is that the stove is on a lower level, but due to the general set-up only 12-15 feet of flue is needed for actual venting, but then some portion of the house extends up as high, or higher than the flue.
It's my .02 that the 'minimum requirements' for the stove flue are probably specified with the expectation it would be in a 'single floor' situation - like a ranch house or similar. When you put it in a house where another portion of the structure extends above the stove - that part of the structure can also act like a chimney. So now you basically have two flues fighting each other. Throw in some other factors which can reduce draft like moderate temps instead of bitter cold, humid air / rain, flue on the outside of the house or outside wall, less than adequate flue insulation, bath fans, kitchen fans, gas appliance flues, clothes dryers, or anything else which reduces draft and suddenly that 'just over the minimum' flue is really inadequate.
You could try temporarily opening a window in the stove room. The extra air would help satisfy other air leaks and allow the stove to run at full potential.
That is probably a stove pipe thermometer. Not a stove top thermometerStove is at 570 now with really strong secondaries. Could it just be that I was cutting it back way to early? I felt like I was ripping through a lot of wood to get it to a high temp so maybe I was just being stingy and cutting it back too soon? In other words is there a critical temp I should be at before I cut it back at all? Also what range should I be keeping the stove at? The stupid thermometer I have that I dont use says over 450 is too hot but I'm hearing a lot of you guys say you run it to 600. Its a cast stove with soapstone in it and the docs that came with the stove didnt say
Yep. Just read the numbers and ignore the ranges, it will work fine.That is probably a stove pipe thermometer. Not a stove top thermometer
That would be well in the safe range. My stove routinely hits 750 after reloading.With that in mind, what stove top temperatures are generally safe? I see people talk about the 5-600 range a lot
I burn at 600 all the time, unless it's cold then I go to 650. 600 is jo problem.Haha yes and I'm sure that I'm overthinking this because I'm a perfectionist and I wasnt as prepared for this season as I wanted to be. My only issue with ordering more right now is storage. I have tons of land to put it on but haven't really built anything to keep the wood off the ground so even the 6 I have are stacked on the ground with green tarps covering the tops. I know that it's less than ideal
What does the manual say?With that in mind, what stove top temperatures are generally safe? I see people talk about the 5-600 range a lot
Hearthstone Manchester. It does not have the output of the first generation, but it doesn't seem like he's getting consistently good secondary burns so there may be other issues such as wood dryness, operation, etc.Sorry if I missed this but what stove make/model is this?
The manual says be careful not to over fire the stove and then doesn't give any suggested operating range which I find ridiculousWhat does the manual say?
Yes. And learn how to ID Oak so you can separate it out; It needs two years to dry..if the splits aren't too big. Three years if they are big.should I buy more now?
