I like big, especially if the house is going to be cold and need a large push of heat, but the Super is a good performer.
So you would recommend something like the PE Super Insert over the Jotul C450 because the PE is a hearth insert?
Any stove with a convective jacket around the firebox can work very well in a fireplace, as these stoves move a much larger amount of their net energy using convection
You may lose a bit, but if you look at convective stoves (have a air jacket) or any insert, they are designed to move the heat out into the roomBut I think a big part was also the fact that it seems that if I stick it deep back into the alcove, I'm not going to get the radiant heat benefit anyway. Ashful has said that sitting one back deep into the fireplace would be a big mistake.
Both are good inserts. The PE has a bit of an edge because it is larger, has a unique baffle system and a coupled secondary air control. The Jotul has an edge in the looks dept..So you would recommend something like the PE Super Insert over the Jotul C450 because the PE is a hearth insert?
Any reason there's not a BK Ashford 20 or 30 listed above?
100% agree with Ashful
So, today both exist. I suspect that, had folks not had bad experience with the early and improperly designed cat stoves of the 1980's, non-cats might have never existed. As to the pros and cons of each, you could read arguments on that topic from now until the end of time. Both work very well at medium to high burn rates, but only cats work as well at low burn rates. There are not any extra maintenance requirements of cat stoves, other than replacing your combuster every 5 to 10 years (about $200), and keeping the gasket on the bypass damper in good order.
Web page isn't working for me right now. Resources are all being put into R&DNo, those burn times are not exaggerated.
Yes, it is very nice to be able to load both ways. I usually load N/S for faster starts and I am able to pack the stove more without concern of a log rolling up against the glass. If you like the 2.5 cu ft size firebox take a look at the Enviro Boston. It will load 16" N/S and has good WAF.
