Recommended Installers in Maryland?
jaybird17
3
Md
Hello everyone! I recently purchased a new home with two, large fireplaces. I have zero experience with wood stoves, but I consider myself relatively handy and a quick learner. I've been reading pretty much non-stop the last few weeks and feel like I have a good understanding of the basics.
A little context - I just purchased a 4000 sqft split level with a large internal chimney running through the center of the home. I'm not looking to heat the home entirely by wood, but I'd like to create as much heat as possible since the home is all electric otherwise and will be very expensive to heat (electric baseboards currently). Upstairs has a large two-sided fireplace, and downstairs has a regular fireplace. I'm planning to install downstairs since two sided stoves don't seem to really exist in this country, and heat rising will radiate better throughout the house.
I've also learned that inserts are inherently less efficient than standalone stoves, but for space and aesthetics, I'm willing to settle. I also know that for pure efficiency, cat stoves are the way to go. Again, I'm willing to sacrifice efficiency here for something that makes prettier flames.
Anyways, after extensive research, I'm leaning towards going with a Lopi large flush hybrid insert. If this sounds like a bad idea, please feel free to suggest something else. I'm also looking for a high-quality installer. There are a couple of installers in the Baltimore area with decent reviews, but none seem to work with Lopi products. I've also had the chimney inspected and it's luckily in great condition. Are there any installers out there that work with Lopi and do high quality work in the Baltimore - Washington area? I am willing to pay a premium to have this done correctly by someone who knows their chit. Thanks in advance!
It looks like Watson's is a Lopi dealer 410-321-5855
Thank you for sending. I’ve learned a lot from your previous posts and have decided what products to go with, based on your recommendations. Unfortunately, I didn’t have the best experience with them when inquiring. Makes me hesitant to spend this much money with someone I’m uneasy about. This purchase is a significant investment for me.
I'd like to reassure you that you are not compromising much but going for a hybrid insert.
Hybrid = cat + tubes.
Modern Noncats are about the same efficiency as cat stoves. And inserts can be the same as freestanders. You only need a blower for inserts.
Is the chimney lined with an insulated liner?
Reactions: jaybird17
It might have been that particular sales person. Ask to speak to the owner.
You could also try Yelp or similar local services rating system for referrals.
That is great to hear! I am unsure if chimney is insulated. It has the original clay liner which is intact and in good shape. Is this adequate insulation? An additional metal liner would be used upon installation of an insert, correct?
Yes, I would install an insulated stainless steel liner. For safety, performance, and code compliance.
