midwestcoast said:BrotherBart said:midwestcoast said:BB, you say I should never close the air completely with this mod, even during overfire? Danger of backdraft even if 2'ndary air is unrestricted?
Yep, I am the magnet guy. And no you don't close it all the way down. Gotta have some flame to feed the gases to those tubes up top. Essentially what you are doing is turning a EPA stove into a pre-EPA stove with secondary burn. Shut off all the primary air and some time later you are going to have a smoldering pile of crap in the bottom of the firebox. And not enough heat and a chimney that you ain't gonna like looking down.
If you feel the burning, pun intended, need to close the primary all the way down. Leave it alone like it was designed. And let the unrestricted inlet go its job.
Thanks, but I think you missed exactly what I was asking. As I said, I never close the air all the way, for the reasons you stated. What I'm asking is: During an active overfire, and given the blocked inlet, should I keep the air cracked open to avoid a backdraft? Even though secondary air is still open?
Redacted post by Jags.
(post was going to confuse the issue)
