O
oldspark said:Any chance of a back draft when you snuff out all the air like that?
Flatbedford said:In the year and a half or so that I have been reading and posting here at Hearth.com I have never seen Brother Bart's rule about not adding splits to an inferno, or what ever it is. I often add splits to my Fireview at all times in the burn cycle, because I am leaving the house or going to bed. I don't go far away and keep the air setting low. After a few minutes, I engage the cat and lower the air to usual setting. No inferno, no run away. Maybe my wood is not as well seasoned as I think?
At that point your day gets even more interesting.BrotherBart said:oldspark said:Any chance of a back draft when you snuff out all the air like that?
Yep.
Ducky said:OK I have my stove in my garage, which I run 24/7 and only a couple times did it get a little hairy for me (i am a new burner on my 4th year now - still learning) I have about 5 or 6 large fire extinguishers with in easy grabbing distance as well as my water hose...
If things got out of hand, what would happen if i hit the stove with cold tap water? Of course I wouldnt be standing right next to it, but in a 'emergency' outside of calling 911.. what would happen?
A couple people have said that the stove could explode....
Tin foil with a hole or 2 in it?oldspark said:I like the idea of reduceing the secondary air but not totaly closing it off, pulling oxygen down the chimney and the stove gases ignite scares the hell out of me, maybe cover the secondary air 3/4 or so makes more sense?
Good idea that. As I understand it though, not all manufacturers do it that way. My Regency is made in Canada & many are sold there so EPA Regs don't always apply. I believe Regency added an extra hole to my U.S model that's always open (or was until I blocked it to get rid of an annoying howl).Todd said:Why not fix your air control so it shuts completely off? I know in order for a stove to pass EPA clean burning standards the manufacture rigs their air controls open a hair but in some cases this could turn into a safety concern. Can't be too dificult to grind off those tabs that keep the air open.
midwestcoast said:Good idea that. As I understand it though, not all manufacturers do it that way. My Regency is made in Canada & many are sold there so EPA Regs don't always apply. I believe Regency added an extra hole to my U.S model that's always open (or was until I blocked it to get rid of an annoying howl).Todd said:Why not fix your air control so it shuts completely off? I know in order for a stove to pass EPA clean burning standards the manufacture rigs their air controls open a hair but in some cases this could turn into a safety concern. Can't be too dificult to grind off those tabs that keep the air open.
Well, I am pretty sure it's just an additional primary air inlet that I blocked, not secondary, so I don't see the EPA officers busting me. I get the light show as normal. It's an "idiot hole" IMO. Put there so that no uninformed, non HDC-reading user shuts the air off completely each night before bed thinking the fire will glow nicely through the night. I never close the air off completely.Green Energy said:Separate air intake from the primary air - so the primary air control has no effect on secondary air. Isn't it against the law to alter the stove so as to be able to shut off the secondary air?(Not that the EPA can do much about it while its in your home). But it does probably render the stove to no longer be EPA certified, and therefore, not in compliance with local code for stoves in many parts of the country.
Also, under normal operating conditions, you want the secondary air, as designed, to achieve the efficiencies, reduce the creosote, and provide the light show. The low air sucking noise is a small price to pay.
midwestcoast said:BB, you say I should never close the air completely with this mod, even during overfire? Danger of backdraft even if 2'ndary air is unrestricted?
firefighterjake said:By biggest concern was not so much the actual temps, but rather that the temps were steadily increasing with no sign of slowing up.
Ducky said:why not close off all the air during a runaway? close off the air, close all the damper and let the sucker burn itself out
Semipro said:I think I'd be more worried about cracking my stove because I changed the temp too rapidly by throwing wet newspaper in it. Cast iron is pretty tough stuff but will crack readily if thermal expansion/contraction doesn't occur uniformly and slowly.
I've been concerned that my Oslo was getting too hot once or twice so I experimented by going outside and covering the OAK intake; it slowed the fire nicely. That's one advantage of OAKs you rarely see mentioned. Putting your arm back under a stove that's overheating to block the air intake isn't fun. That's one when I'd much rather go out in the cold.. unless that coon is still waiting for me.
BrotherBart said:Ducky said:OK I have my stove in my garage, which I run 24/7 and only a couple times did it get a little hairy for me (i am a new burner on my 4th year now - still learning) I have about 5 or 6 large fire extinguishers with in easy grabbing distance as well as my water hose...
A lot of steam and a very real possibility of cracking the stove. You need to take care of what is happening in the firebox. Not outside of it.
BrotherBart said:midwestcoast said:BB, you say I should never close the air completely with this mod, even during overfire? Danger of backdraft even if 2'ndary air is unrestricted?
Yep, I am the magnet guy. And no you don't close it all the way down. Gotta have some flame to feed the gases to those tubes up top. Essentially what you are doing is turning a EPA stove into a pre-EPA stove with secondary burn. Shut off all the primary air and some time later you are going to have a smoldering pile of crap in the bottom of the firebox. And not enough heat and a chimney that you ain't gonna like looking down.
If you feel the burning, pun intended, need to close the primary all the way down. Leave it alone like it was designed. And let the unrestricted inlet go its job.
