the blaze king will creep up there with ease. in bout 10 min after reload it can be up pushig the 700 mark. the i say well time to back it down. dont see any issues. guess its a good indicator that the wood is dry. just gotta keep the eye on her.
southbalto said:The manual for the oslo indicates an optimum surface temp of 400-600 degrees. Why were you sweating mid to high 500s?
i shut down my jotul last year in a pinch by stuffing the air intake with foil.....It's effective.
op_man1 said:500 stovetop doesn't sound that hot to me... Was it the flue temps that had you worried? Excuse my ignorance!
Backwoods Savage said:Jake, thanks for posting this if only to show that even us with much experience can still make some dumb mistakes. However, it also shows that experience allows us to keep our cool to get the situation under hand.
I agree you probably did not harm to the stove but perhaps a bit to your ego. I would not have been concerned about the stove top temperatures but with the flue temperatures going up high that would concern me a lot. As for you adding wood when the stove was that hot, you definitely should have known better and I'm betting you learned much from that error. I don't know if removing that extra soapstone would have helped much but probably would have tried to remove it to let the heat dissipate more rapidly.
As for the wood falling into the glass, that is one reason I like the Woodstock design so that can't happen.
All in all, I'm very glad this worked out well in the end for you. Caulk it up to one more lessen learned. I will no doubt be our last.
zapny said:Jake did you load n/s or e/w?
zap
Glad things are good and nothing got away.
BrotherBart said:Green Energy said:I know the temptation - time to turn in and I did not time the last load very well, so I want to top off the stove so that I have plenty of coals in the morning. Last winter, I also learned my lesson. Definitely scary when the stove temps take off and everything in the stove is flaming. So I learned the importance of planning the reload. Timing is everything...
A guy that doesn't post here anymore said it best. "The art of wood burning is timing the coal bed for the overnight load.".
Keeping a few small pieces around for the times that the timing is off is priceless.
And thanks for posting Jake. Saves a few new burners in EPA stoves from getting the crap scared out of them. Watching secondary burn is kinda fun but it can turn into serious fear when it turns into an inferno in your living room.
firefighterjake said:zapny said:Jake did you load n/s or e/w?
zap
Due to the set up I almost always load East-West unless I'm burning some chunks which are omni-directional.
FixedGearFlyer said:My wife rolls her eyes at me for this, but . . .
My life has been spared many, many times in airplanes because I followed procedures that were ingrained in memory through drills, dry checklist run thrus, and careful simulation. I've had inflight fires, engine failures, bird strikes, failed instruments when flying in the clouds, and more, but have always been able to stay calm and fall back to procedures that have relatively assured outcomes. If a procedure fails to have the desired outcome, there's usually another layer of fall back procedures underneath the one that failed. Most often, it's only when all procedures have failed or when they aren't followed to begin with and pilots start "trying things" that lives are lost.
When something becomes THAT ingrained in you, it bleeds over into other parts of your life, so I've spent hours sitting in front of the wood furnace going through the 'what-ifs' and creating checklists for chimney fires, run away scenarios, broken door hinges, failed plenum integrity, power outages, etc. The checklists and required tools (Chimfex extinguisher, regular fire extinguisher, pre-cut heavy foil to cover the baro damper, pre-cut heavy foil to cover a broken loading or ash pan door, pipe caps for the modified secondary burn tubes, etc.) are all sitting in the furnace room, ready to go.
I've made my wife go through the drills and memorize the checklist "Memory Items" (those items that are so urgent you may not have time to get a checklist and review it) so that, when I'm not home or am traveling for business, I know that she can handle whatever might happen. The first time to read the directions and actually strike a Chimfex is NOT when a chimney fire is roaring above you and the first time to put a piece of foil over the loading door opening is NOT when the door has actually broken off and the stove is running away from you. Mechanical actions like those should be second nature, otherwise the action of figuring it out and the questioning uncertainty that go with it will lead to panic and failed outcomes when the real situation occurs.
Those checklists are designed to save the house and our belongings and I think most of those situations can be resolved safely with a calm set of calculated, practiced actions. But the real desired outcome is that my wife, my son, our unborn child, and I are all safe, therefore, the ultimate checklist has one item on it: "1. If you have lost control of the situation, get everyone out of the house immediately and call 911." I can handle losing my home. I can't handle losing the people I love and the true desired outcome of any situation has to be recognized on the front end.
As pilot-geeky as it sounds, I can't imagine having a wood stove or wood furnace in my house without also having thought through exactly what to do in the unlikely but "common" potential issues.
Believe it or not, I'm NOT a type-A controlling personality - unless it's something that's related to safety. Then my years of pilot training and working for aircraft manufacturers as a flight standards pilot kick in.![]()
flyingcow said:firefighterjake said:zapny said:Jake did you load n/s or e/w?
zap
Is that a "Unity" term for short pieces ? You sell omni-directional wood" to the flat landers for extra $$$'s?
oldspark said:Where are you putting the tin foil, primary or secondary air?
Clodhopper said:Nobody at the stove place mentioned I would need a tin foil ball. Sounds like they've missed a potential income stream. Kind of makes you wonder why these stoves don't have a kill switch air gate, which I would guess would probably be a pretty easy retro fit.
To get yours today, send a $39.95 check or money order to...![]()
Jags said:Yet - you run a Vogelzang. :lol:
(I'm just bust'in your chops ;-))
firefighterjake said:Folks like you are what gives me confidence in flying . . .
