I occasionally have fires overnight which get really hot.
This is a Suburban insert, secondary combustion tubes have been added to it. It has an 8" single wall liner running 13' straight up a masonry chimney. Occasionally I will get a hot overnight fire - this past Tuesday I loaded it and went to bed. Woke up two hours later and internal flue temps were at ~650f, the side of the firebox was measuring ~430f (measured with K-Type thermocouples). Outside temp was about 50f. My wood pile is mostly oak, bradford pear, and maybe some hickory and pecan mixed in.
Most nights it will burn with flue temps in the 425-500f, firebox side at 325-350f. I set my air controls to the same spot every night.
It did this a few times last winter so this year I dollar bill checked my door gasket and it seems ok. The ashpan gasket was loose so I replaced it and it is now tight.
I can close the secondary and primary air and the stove will cool.
Anyone else experience this? Suggestions on how to manage it?
-Or perhaps should I even be concerned with it? It will sure make a load of wood disappear quickly!
Thanks!
Thanks!
