Obviously you are the smartest person to ever burn wood and are REALLLLY hung up on creosote aspect of my post. I am hung up on too dry wood so go smoke that if you need to. I found one of the articles that I saw the other day and could not find it previously till now. And you show a hint of ignorance in saying dry wood is a 2x4! Well we all know that not all 2x4s are the same. Sooo that said until you understand a dry climate that is 10-20% humidity just play in the forest.
The Wood Heat Organization was formed to support the public in the responsible use of wood energy in the home. We fulfill our mandate by providing reliable information, by conducting research into wood heating-related issues and by representing the public interest in discussions of policies that...
www.woodheat.org
It says
Can Firewood Be Too Dry?
Yes, although it is not a common problem
Properly seasoned firewood still has a fair amount of water in it, say 15 to 20 percent of its weight. That water regulates the combustion process along with a few other factors like piece size, load configuration and combustion air supply.
The higher the fuel moisture, the slower the wood breaks down when heated because of all the heat energy soaked up in boiling the water out of the wood and raising the temperature of the steam.
Conversely, the dryer the wood, the more quickly it breaks down when heated. By breaking down, I mean the vaporization of the volatile components of the wood; that is to say, it smokes. The dryer the wood, the more dense is the smoke at a given heat input rate.
Since wood smoke is fuel, we want to burn it as completely as possible and that means mixing with adequate oxygen in the combustion air. The problem is that a firebox load of very dry wood produces far more smoke than the air supplies of stoves are designed to provide. Besides, even if you could supply enough air, you would produce an inferno that would howl in the stove and make everyone in the house nervous. Fires that intense can seriously damage the stove's innards. Wood that is very dry produces a fire that is hard to control without making a lot of smoke.
Kiln-dried wood is down around 10 percent moisture. Depending on climate and conditions of storage, normal firewood won't dry down to kiln-dried moisture because of normal outdoor humidity. For example, I've never measured wood below about 14 percent in my firewood supply. But I suppose that firewood could get very dry by natural seasoning in desert conditions. Or firewood stored in old barns, which are like kilns in hot summer weather.
The right band of firewood moisture is between 15 and 20%. When you get much over 20% you start to see symptoms of sluggish ignition and the inability to turn down the air without extinguishing the flames. Towards 30% the wood sizzles and fires are very sluggish and it is hard to get a clean burn until the wood is almost to the charcoal stage. Above 30% water bubbles from the end grain when the wood is heated and it is very hard to burn at all. Species like poplar/aspen, which have very high native moisture content are virtually non-combustible when not adequately seasoned.
The main difference between EPA low-emission certified stoves and conventional stoves is that you can turn down EPA stoves for a long burn without extinguishing the flames. That is, they are better at producing a clean, controlled fire. The EPA test method requires wood with a moisture content between 16 and 20 per cent (19 - 25% dry basis) and when the wood is outside this moisture band, the stove's emission rate goes up. So even the best wood stove's performance will suffer if the wood is not in the right moisture range.
If you have some very dry firewood, like kiln-dried cut offs or old wood stored in a hot place, mix it with regular firewood to raise the moisture content of a full load.
JG"
