I'm having the same issue with a New Discovery 2 (3 weeks old) that is very similar construction if not the same as yours. I had the dealer out and called the manufacture. Dealer stated it was a weird burn (my words) and manufacture stated it was normal. Here is what I got. If you load a log (spilt) at a time the stove runs great and controllable , around 350 degs.. If you load it like your going to leave for a bit or load it up for a long burn time like going to bed, then the stove will have this Huge temp swing. 350 to 700+... The top end being past 700 as it pegs my thermometer that has a 700 limit. If you 1-2 logs or splits, the running temp is around 300-400 and controllable and nice even heat/output. However anything over 600 it warms things up pretty fast.
I understand the need for that but not when the house is already warm. So here is what I've done. Pulled the sides off to expose the controls. found the controls all closing like they should. so I started rolling up tin foil and closing the temp control setting on the rolled up tin foil and loaded it up again.. The darn thing still pegged the meter at 700.. I had the dealer present when I did this and he was amazed. He called Quad and they told him it was running properly and they need the air to meet EPA (which I believe) and that "all stoves" that are EPA approved run this way. (This I don't Believe). Manufacture stated many people mess with the air control like I did, to improve burn control and only end up with a creosote monster. (i'm not sure I believe that either, because at 700 degs I think it would burn the creosote, I'm sure someone will enlighten me on that in here) So if I were you, would check your side controls and make sure they r closing as designed and the leaking door gasket. Which I did on mine too but for got to write about it. Sorry![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
I'm trying to return my for a refund, Keeping fingers crossed and will go with a BK like I wanted. My problem is the size/shape of the stove needs to fit in my location. If you have any questions just yell..
Thanks for the add to the forums
Jim
Jim
