So my first impressions of this thing is holy crap it looks a lot bigger in my house than at the store. I currently have a Vogelzang Defender that I use at my cottage and I thought that was decent sized but this thing is just big. I noticed n some of the finishes aren't quite as nice as other stoves.
So the bad:
There is a little welding slag on the pedestal which is much thinner metal than i figured it would be. The air intake on the back wasn't deburred at all and still very sharp with pieces hanging off it. The advertised 6" flue is about a 1/16 smaller in diameter making it almost impossible to properly fit a 6" dura vent (brand recommended on the side of the box) single wall pipe. The air damper spring contacts the door everytime you open or close the door.
Now the good:
This thing is built like a tank all 435lbs. worth. The stove is built with 1/4" plate or bigger is a heavy duty stove and should service my family for many years. Moving this by myself took some serious thought and ingenuity being i had lowes load it into my pickup bed. The viewing glass seems to look sealed nicely but i haven't checked the actual door gasket yet. I was looking for something with a big firebox that will put out some BTUs and i think i found it. The firebox is 3.25 cu.ft. according to the specs on the stove. It's big enough i could probably fit the whole top of my defender inside the fire bricks. Another nice thing about the stove is that it fit thru my doorway. It's 27" square if you include the front catch tray.
All in all I'm pleased with my purchase so far and didn't expect to get the attention to detail a $2000 stove will have. I needed something functional on a budget and this stove seems to fit the bill. After i do the break in burns and get this thing going i will comment back about the performance of the stove. I'm looking forward to the heat and money it is going to Save me compared to the fuel oil.
Sent from my SM-G930V using Tapatalk
So the bad:
Now the good:
