Pascal_Maertens
point 1. I'm not sure what you have been said for you to clean this every week ?? cause I clean mine every 50 pouches including my chimney pipes. but for the size of it, if you are confident maybe just a little sanding could do the jobHi everyone,
We've had our Monia since October, it's been great all winter and is saving us a ton on oil. This site has been an invaluable resource for a new stove owner. A couple of questions for fellow Piazzetta owners:
- Is there a trick to removing the rear baffle plate for weekly cleanings? Every week when I remove, it seems like getting it out and back in again is a struggle. It feels like the width of the plate is the exact width of the inside of the stove.
- Occasionally, after the stove is shut down completely, 10 minutes later, we can smell smoke that seems to be left over embers still burning. This doesn't happen often, but it happens. Have anyone else experienced this?
point 2. there is a way to adjust the convection blower to stop latter refer to a technician to have the program p-13 lowered to 40celcius it is at 43celcius by default this way you combustion fan is going to stop at 40 Celsius less chance to have red hot ashes
point 2. also as I said in the post ((configure your stove to be auto clean more often and also for a longer period of time, I explain; in the configuration program you can adjust the pot or grate cleaning interval from; 30 min to 180 min by default it is set to 60, I settled mine for 30 minute. Also the grate cleaning time can be change; from 10 sec. to 30 sec. I set these one to 30 seconds even if it seems to be very little changes it makes a big difference.
all of these adjustments need to be done by a tech, of curse someone can give you access to all of dose codes ( irresponsible people ) but I assure you that it can be very dangerous to make modification to some codes whit out proper knowledge it's better to pay a little extra to get satisfaction. By the way if you would be my customer there would be no charge for this kind of adjustments cause you would have get it set up anyway on the FIRST START of your stove that's what WE call service you can ask your dealer if they are responsible they might just go and fix it for you no charge.
good luck
Pascal
![[Hearth.com] Piazzetta Monia opinions [Hearth.com] Piazzetta Monia opinions](https://www.hearth.com/talk/data/attachments/131/131211-c53cd96fe25f22356354c451c7993dc7.jpg?hash=wmWpc4SzU0)
