To remove the crystallized salts.what is the reason for soaking in water?
Thanks, I may have to try it alsoTo remove the crystallized salts.
hello...just found this forum and was wondering if pascal was still available.....have a monia......two years....
Drop him a message, he posted last month, so I assume he's still active.hello...just found this forum and was wondering if pascal was still available.....have a monia......two years....
If you go to the first page of the Pellet Mill, you will find a permanent thread with information on the Piazzettas.hello...just found this forum and was wondering if pascal was still available.....have a monia......two years....
yes I come once in a will just to check if anybody needs help. what can I do for you ?thanks and thanks for your response ...will check it out........
well I have always recommand to run the stove at power level 3 cause at 1 and 2 there is no self cleaning procedureswas using power saving mode...with a power setting of 1, then changed it to 2, cause it seemed to be sooting up quite a bit...it seems a little better now.....recommendations appreciated......
you need to clean the grate every number of .... ? dayi clean it regularly...burn pot or grate, seems in good shape.....
well this issue on a monis is well kwnone I circerely never sale Moniabut the internal baffle is a bit of a pain to remove...i don't think my wife could remove it if i kicked the bucket.....as i mentioned before....stove should be advertised "for men only" ....i have to lift it off with a screwdriver an pull it forward so i can grab those two tabs to remove it....takes a bit of practice so i don't jam it....
well only if the stove goes off and back on with in 15 minute or less. du to a bad house insulationyou mentioned that in this mode the igniter burns out more quickly, which is my concern..
what ever the problem I will be abble to help you out. beside the baffle issue ..also is there a exploded diagram or whatever to show the inner construction and explanation on how to do repairs or internal cleaning...the stove reminds me of a brass instrument...you know where it goe in and where it comes out, but where it goes in between...nobody knows .......the people at the lumber yard here, don't know much about it....i only found your great contribution just yesterday.......so i'd have to do my own repairs whenever it will be necessary......i guess it's past the two year warranty now....
thanks for your time and selflessness .....much appreciated....cheers, vic
The backplate issue seems to have affected a few Monias. You may be able to search old threads for a solution or perhaps Pascal remembers what they did.hello, bonjour pascal.....ha, i used to live in montreal, and play in a band on weekends in st. sauveur in nymarks inn....long time ago... i'm 75 now and live up in burns lake bc....
i'm not good at reading or understanding instructions, but i try .....i have a monia on the main floor, and it seems to run quite well, and i'm quite happy with it.....third winter coming up....i use it until the temp goes below -5 or so, then i use the wood stove in the basement...
it's exiting the roof...maybe 12 foot pipe.....was using power saving mode...with a power setting of 1, then changed it to 2, cause it seemed to be sooting up quite a bit...it seems a little better now.....recommendations appreciated......
i clean it regularly...burn pot or grate, seems in good shape.....but the internal baffle is a bit of a pain to remove...i don't think my wife could remove it if i kicked the bucket.....as i mentioned before....stove should be advertised "for men only" ....i have to lift it off with a screwdriver an pull it forward so i can grab those two tabs to remove it....takes a bit of practice so i don't jam it....
you mentioned that in this mode the igniter burns out more quickly, which is my concern...also is there a exploded diagram or whatever to show the inner construction and explanation on how to do repairs or internal cleaning...the stove reminds me of a brass instrument...you know where it goe in and where it comes out, but where it goes in between...nobody knows .......the people at the lumber yard here, don't know much about it....i only found your great contribution just yesterday.......so i'd have to do my own repairs whenever it will be necessary......i guess it's past the two year warranty now....
NO, but it's not the model that I would recommande the most, I usualy recommande the Sabrina model.thank you pascal........do you mean you don't sell the monia model any more?
