Pelpro pp130. Lazy flame. Overflowing burn pot. All of sudden Only 1 ton pellets in.
if you are dead set on ignoring safety features for modern stoves. i would advise not putting a fan on the intake but to raise the HP of the combustion fan already there. draw more air through the stove instead if forcing it into it.
Reactions: johneh
Hey Jeff, I just finished doing a lot of tests and modifications to my pot and came up with a design that works very well for me. My stove runs full blast 24/7, some days almost burning 3 bags in 24 hours. I also had a lot of ash accumulation in the burn pot after 24 hours. To the point that the flame was so lazy that I was just basically wasting pellets. A lot of people burn only a bag or less in 24 hours, so they don't have this issue and will just tell you CLEAN YOUR STOVE REGULARLY. Which I agree with, but I am someone who refuses to leave any performance or efficiency on the table with anything.
I am currently waiting on a new burn pot to be shipped so I can build a cleaner version of my "test pot" It functions flawlessly, but there was a lot of welding, drilling, welding, drilling done so its no visually pleasing. I plan on making it very clean by tig welding the holes shut and laying out the holes evenly spaced. My test piece was mig welded and the holes location was based off of where ash was building, and varying hole sizes to accommodate for where more or less flow was needed due to the factory router of intake air.
I can assure you that simply drilling additional holes in the bottom will not produce a great result unless you significantly increase the volume and speed of the air (I am working on a set up for this as well by increasing exhaust fan speed). In all of my tests, the majority of factory holes must be welded shut.
I can send you pictures and rough numbers of hole size if you are interested. But don't judge my welds, I didn't feel like spending tons of time prepping and tigging just to possibly drill it back out lol.
Here is some pictures of after my final mod. This was 48 hours running full blast. I also have an excel sheet and word file explaining the progression of the modifications and comparisons to stock.
Edit: Also, don't think of this as a "never clean your stove again" type of modification. As you can see, all the ash that would typically build up in the pot is now piled up inside the firebox like some higher end stoves. I still vacuum every 2 or 3 days, but its a 2 minute process. I let the fire die down, open the door, and vacuum all the cool ash out from around the pot and firebox, shut the door and let it go back to normal. Opposed to shutting down, vacuuming, pulling the burn pot, scraping for 15 minutes, and turning back on.
[Hearth.com] Pelpro pp130. Lazy flame. Overflowing burn pot. All of sudden   Only 1 ton pellets in. [Hearth.com] Pelpro pp130. Lazy flame. Overflowing burn pot. All of sudden   Only 1 ton pellets in.
Reactions: Squatch6 5 and _56
View attachment 308120 View attachment 308121
I would love pics and specs if you get the time! My pp130 stove is in my barn where we have our business, and due to her and her employee's schedules I can't always get in there every day to shut down and clean the stove. Being able to go 2-3 days if needed would be a life saver! My email is the same as my user name at g mail if that's easiest to send. Thank you!
I will try and get it sent over to you tonight. Don't worry about reading through the word document too much as it was just something I did as a notebook for myself. In the bottom section you will see a couple notes about hole size and location for the last modification. Feel free to ask anything.
You're awesome, thank so much!
Yes it has been running all winter and doing quite well. As I stated in an earlier post it really made a difference for me when the wind is out of the north west, the flame doesn't get snuffed out by the back draft like it used to. I had to experiment with the trim a bit and found the -3 to -4 is where it works best. I was actually looking at hopper extensions for them since I don't have to shut it down everyday to clean the burn pot out like I used to. I could never justify adding a hopper extension if I had to be there to service it daily anyway I figured I can also throw in another bag of pellets after I cleaned it. I generally don't shut it down to clean it until I see the ash in front of the burn pot build up an an half to two above the bottom of the glass. Depending if it is set on low or turned up really determines how many days it will run before it gets that much build up in it but I generally don't have to clean more than twice a week and in some cases once if it hasn't be turned up above low much.
I am intrigued with your burn pot mod...... I live in Idaho at high altitude, 6500 ft, and have been having issues with ash build up no matter what brand of pellets or adjustments I have tried. As I understand it, all holes except for the igniter port, have been plugged of and the grate pattern drilled into the bottom...? Is it possible for you to provide a better picture of your mod ? Surely appreciated
Sorry guys, I've been out of town working around the clock. These are some junk photos but all I have to work with right now, I'll upload pictures of the stainless pot I made that looks more professional. But the red holes are 1/4", blue is 3/16", and unmarked are about an 1/8".
All the holes in the outer perimeter are slightly angled in towards the center to make a nice lifting flow and tight flame. Not super important, but it's what I did. Most importantly I'd say make sure you have at least the amount of holes I have as any less than this I wasn't having sufficient flow. The one hole on the back angled piece I left as kind of a safety, so if something bad happened there would still be some air going to the pot.
[Hearth.com] Pelpro pp130. Lazy flame. Overflowing burn pot. All of sudden   Only 1 ton pellets in. [Hearth.com] Pelpro pp130. Lazy flame. Overflowing burn pot. All of sudden   Only 1 ton pellets in. [Hearth.com] Pelpro pp130. Lazy flame. Overflowing burn pot. All of sudden   Only 1 ton pellets in. [Hearth.com] Pelpro pp130. Lazy flame. Overflowing burn pot. All of sudden   Only 1 ton pellets in.
I realize this is a slightly older posting but if your trying to increase the air flow through the burn pot wouldn't removing some of the restrictor plate that is located in the fresh air intake tube achieve that easiest instead of changing exhaust blowers or adding intake blowers. I drilled two 3/16 holes through the plate and it did wonders for my stove at the lower settings. Both the standard 130 and the 130b stoves have them. I'm not saying this would fix everybody's the same but it made a world of difference for me. Just my two cents worth. This is a great place to both teach and learn with only the occasional condescending comments.
On my Harmon XXV I wanted to have more Airflow and just used Magnet. It really helped a lot, but I found the problem (Screen I left in Pipe to keep stupid Birds out in Spring/Summer). Amazon has tons of them. Do not get one too weak or small or too big.
It has been a while since I have read any posts here and am quite impressed with what shoe1757 has shown off here.
ANDYSEP--I posted a couple of pictures early in this post, sorry not as detailed as shoes1757 pics, but basically you can see I drilled a bunch of small holes close together as I stated in the earlier post on the bottom. I then added a couple on each side, front and back. Later I actually took the removable plate from my SS one I have and installed it as is to see if a little additional air flow down from the top would help feed the flame air and still keep the ash from building up in the pot. It did improve things also. I really think shoe1757 did a nice job and has a better design that what I have and I may purchase a new one to modify in that fashion.
I got back on in part because I wanted to share another mod I did, that now after seeing what others have done here may be a mute point. I was still having some issue with burn pot filling up over time with pellets when the dial was turned up above low. Basically I run it for an hour or two turned up and then turn it back to low to slow the pellet feed down and it would clean out the pot if ran for a while. I installed a timer relay in series with the vacuum switch and found that with the trim set to 0, thermostat turned above low to about half, time "on" set to 30s and "off" for 15s it really has done a good job of producing a nice flame and does not build up ash or pellets in the pot like it use to. Basically I just put a 15 second interrupt in to the regular cycle, which I more or less figured out by opening and closing the hopper lid and timing with a stopwatch on my phone until I got a good consistent flame and not allowing the burn pot to start building up with pellets.
To describe the quality of the flame it would be best by saying that it appears like the flame you get after it has been thoroughly cleaned out and after it has built a new fire and ran for about 30 minutes. Attached is the picture which is probably much better than my description of it. Again great stuff and thanks for everybody sharing of the ideas, pictures and results.
  • [Hearth.com] Pelpro pp130. Lazy flame. Overflowing burn pot. All of sudden   Only 1 ton pellets in.
Reactions: johneh and Ssyko
