I did a little test on the stove (Pelpro PP130/MFG Date 2/2015) to see if I could better understand just what the trim dial effects. A couple of notes on the test to be aware of:
- I did not verify if the the auger turns the same amount every time it is commanded to to turn. So I do not know if it in fact does incrementally rotate the same amount every time it is commanded to do so.
- The second and and the last setting values were the same in order to see if the sampling was accurate. Other than the RPM speed the dwell time between auger cycles was consistent.
- There was already an existing white line on the fan on top of the combustion fan motor that I used for the reference for the motor RPM using an optical tachometer.
- I waited 5 to 6 minutes in between tests after I made any trim and/or T-stat adjustments.
I would like to know if this is accurate or how it compares to others who may have done this, if anyone has. Other than the low to thermostat setting it really appears there is no significant change in fan RPM by the trim adjust and there is slight dwell time differences in the the off time of the auger motor. If that is the case, it would be nice to have a better control for the auger feed rate. In my case when the wind blows out of the North East I would like to have the fan running at full speed and the dwell time between auger feeds decreased a little more than the current trim adjust allows.
Has anyone every modified a Pelpro with a custom auger timer control or something similar?
I use mine in a good sized shop and really could care less about the thermostat as in my case it is either on low when I am not there or it runs full on even if the setting is on one just due to the size of the garage and temp when I do use it.
Trim Adjustment setting | T-Stat Setting | Seconds between auger feed commands | Combustion Fan RPM |
-3 | Low | 6.09 | 2681 |
-3 | 4 | 4.11 | 3131 |
`+3 | 4 | 3.6 | 3091 |
0 | 4 | 3.81 | 3086 |
-3 | 4 | 4.08 | 3097 |
