![[Hearth.com] Pellet Stove placement help? [Hearth.com] Pellet Stove placement help?](https://www.hearth.com/talk/data/attachments/187/187172-837ee809181596c202e45ff33738435c.jpg?hash=j-SoLkgLY9)
I'm thinking that those power lines constitute a "combustible". Does the pipe manufacturer and/or stove require further than 1.5' away from the center of the vent cap (my manual states 3' to combustibles to front, sides and below)? However, it also states 12" clearance under a veranda, porch/deck etc. is 12".
If you are getting this inspected by the town and/or your insurance agent, it might be best to discuss it with them because it doesn't matter what a manual says, but what they will okay.
You could also possibly spin your end cap say 45 degrees away from the lines shooting down still to direct the exhaust away a bit better while still retaining rain and weather integrity. Just throwing out another on the fly thought.
But as Lake Girl said you could lose a section of pipe and still likely have natural draw for power outages. The exhaust is powered anyway. The vertical is mainly suggested for smoke to continue to escape for a power failure.
This can also be addresses with a UPS which supplies battery power for proper shut down. You have many options and "IF" you are 2 feet below the lines then you are good. That said I'd consider an imaginary circle of 2 feet in all directions like 2 feet out and 2 feet up etc; I really do not think you have a huge concern. The exhaust is only hotter right out of the end and as it immediately mixes with cold air just out a bit it feels like a dryer vent exhaust type heat or hot air. Just follow minimum recommendations for venting in your manual.
. I have a 2001 Cherokee that is down for repairs and i'm working around the clock to get it running again so I can have it to haul the tons of pellets I will need. It's just my luck that my other wrangler's brake line exploded and lost all brakes so that one is useless as well. All we have is this small silver Hyundai car that she won't let me use. !
I don't blame her -You've broken all your toys, she doesn't want hers to be next![]()
Hey I do not advise this but yesterday afternoon I was hauling 16 - 19 bags at a time on my Honda 420 Rancher quad from the barn to the garage. I did 19 bags once on front and rear racks. It worked fine but the Honda was waaayyy over loaded. 19 x 40 = 760 lbs. Hey I do not advise this but yesterday afternoon I was hauling 16 - 19 bags at a time on my Honda 420 Rancher quad from the barn to the garage. I did 19 bags once on front and rear racks. It worked fine but the Honda was waaayyy over loaded. 19 x 40 = 760 lbs.
It was beyond weight limits and maxed out but all I had to do was roll 100 yards. I usually use my tractor with the front loader and a carry all on the back but I have it on jack stands doing maintenance and had to run some pellets in. Plus I wanted to see what I could be dumb enough to do pushing stuff a bit. The quad was easy and I'm walking now but limited as I just got out of two casts with two broken ankles and a broken heel.
Had to get a bit dangerous and industrious at the same time......
Ah come on, gonna be chilly tonight run out and grab a bag or two and fire that puppy up.![]()
Hey guys got a question for another off road member who purchased the same Serenity stove. His location is at 4000+ feet and he was unaware of the need for 4" pipe when he was installing it so he just left the 3" vent and been using it. It burns well and all but he said the vent pipe gets extremely hot and he cannot lay his hand on it or it will, in his words, "burn the s#$! out of me".
Is the exhaust vent supposed to be this hot or is this normal?
