Here is mine with the Ravelli, If I would want to install the Serenity I just remove the riser and put the Serenity on just the board on top of the carpet that is how I had the Serenity for the 3 years I used it.
Well good, I was going to suggest looking into the Castle Serenity when you mentioned the other two stoves above but I see Rich has already hooked you up. Good deal. What kind of price is Ace selling them for now? I still would like to buy a Serenity and may do so but I'm at my limit for now since I also sprung for a new NC-30 wood stove on a spring sale which I have not put in yet. I have to keep the Boss Lady calm with my burning habits around here. Seems every year I buy some new wood / pellet burning toy. Guess i'm a junkie.
I plan to finish stuff up here finally and get the new wood stove in also. I bought it mainly for backup for the pellet stoves. I fell a few months ago and was laid up badly. I broke both ankles and my right heel so I have been out of commission. I am walking again now and out of my casts so I'm looking forward to getting busy here.
Shoot us some pics when you get that new Serenity in. Get it running and tell us what you think. Good Luck
i got the tape at home depot
http://www.homedepot.com/p/Nashua-T...sing-Silicone-Tape-in-Black-1208952/100206050
Also at a lot of local hardware stores (either Nashua brand or X-treme tape). NOT usually found in the heating aisle, but in the generic tape aisle. You may even get your pick of colors.
It's funny how the pictures in the manual show the exhaust vent on the right side of the stove but it's actually on the left. If it were on the right side then everything would be fine.
Not sure how I'm going to do this.
I looked up the manual, and sure enough clearance pictures show the exhaust port on the right. Only if you happen to pay attention to Figure 8, that shows the intake and outtake positions, and the following pictures for the ventilation examples do you question that.
You may be able to use a series of elbows - I had to do that to keep my exhaust away from a window and electrical outlet. You can't see the connections, but this picture shows that my exhaust is offset to the left of my stove - and my stove's exhaust is on the right side.
Hope your healing well and doing the PT like they are telling you! And yes, you are a burning junkie... still giving your lady fits I see.... I also sprung for a new NC-30 wood stove on a spring sale which I have not put in yet. I have to keep the Boss Lady calm with my burning habits around here. Seems every year I buy some new wood / pellet burning toy. Guess i'm a junkie.
Hey BogieB I have a question regarding that stove in your picture. My vent is pretty much the same but going the opposite direction. Do you disconnect the vent behind the stove in order to clean it out every now and then or is that not needed? My vent is really tight the way it is and the only way to disconnect it in the back is by removing the vent from the stove's rear exhaust pipe but that will have high temp sealant on it.
No, I don't disconnect it. I have a cleanout at the bottom of the angle so any soot that may settle, goes there instead. I also use the Leaf Blower Trick (LBT so I haven't had any crud stick at the opening. Here are pics of my pipe and a closer up of where the clean out is.
View attachment 186855 View attachment 186856
Mine just goes straight out. I do have a 45 on the end angled so that the prevailing wind doesn't go straight thru. No, I don't have optimum rise for drafting with only about a foot rise inside. But if power goes out my UPS will allow my stove time to go into shut down mode and to evacuate any smoke. I don't know if your stove will do that, so if you can give it more rise outside I would. In that case, it might not be a bad idea to put a cleanout outside too.Ok that makes more sense to me and I'll do it that way. Did you have a clean out T outside or just a 90?
What kind of UPC you got Bogieb?
I have plans to get a 4000w generator from Home Depot or one of those Predator Gens from HF. We just had the power go out last week and I had to run some things off my inverter that was hooked up to my jeep's battery. It's only 1k watts though. It was funny seeing neighbors slow down as they drove by and noticed my house was the only one with electricity. lol
I have a 3' horizontal only with a turbo cap ... I've been standing next to it when power went off and all I've seen is a wisp of smoke like putting out a candle. Maybe so little due to the OAK but not a big concern with our stove. The smoke alarm gets triggered more from the toaster than the pellet stove![]()
