I don't use or desire a blower (freestanding Super) but some people like to use them to get more air convection heat from it. It probably helps to get some heat into the room on a cold morning for example but at the expense of some radiant heat.With my Super it is noticeable but does not bother us watching TV etc. I have it on low pretty much all the time; would actually be ok if I could reduce the speed even further. I always thought a blower was not really needed with a freestanding stove like the Lopi?
The other thing I have started to recommend is to make a cardboard cutout duplicating the dimensions of the stoves your looking at. Then lay them out on the floor with the appropriate clearances. We were able to tuck the Endeavor tightly into a corner owing to its close clearances and that worked good for us.
I like that idea. Maybe I would cut out the clearances that need to be observed and just paint an area inside that the stove will be. This way you can easily check how much room the stove will really need. (for better understanding: Stove 20 inches wide with 6 inch clearances either side => 32 inches total width; depth accordingly)
To me I see as much sheilding on the PE as the Lopi . Maybe part of the top but that is about it. Very seldom have an issue with noise on Lopi woodstove. Biggest issue is making sure the thermodisc makes good contact for the blower to come on. My bias is showing I know. What can I say I am a Lopi guy through and through.I looked at your stove placement in your original post. We have a Lopi Endeavor and we have been very happy with it. I would point out that I am not sure it will work well for you with the proposed installation location. I did want to point out the Lopi is convective stove with most of the heat output coming out of the front of the stove. The heat output off the back and sides of the stove is pretty minimal. If you put the stove in one of the corners of the room (like the lower left corner of the diagram), it would push the heat from one end of the house to the other. The convection really does work and I pointed our Endeavor towards our hallway leading to the far end of the house and it really works.
Now if the PE stove is more radiant, as opposed to convective and heat shielded like the Endeavor, I think that may heat your home better for you, at least in the current installation location. Just a thought...
Huh. I've heard the blower on the Liberty at the stove shop, and it was really quiet.....My one complaint, and this goes for all Lopis stoves I think (since our gas stove was the same)-the blower is NOISY.
How is it cleaning the 1750?
You won't loose any heat. It kinda depends on the stove to me, my blaze king did great with the blower. It made the stove in my opinion.Can you actually loose heat by using the blower with the wood stove? Would a house fan make more sense?
No, the same amount of heat gets transferred, it's just the difference between convection (heating the air directly) and radiant heat. Mostly a matter of personal preference. I like the radiant feel, so I don't want a blower, but many like them. Inserts tend to need them more, especially if they are on an outside wall.Can you actually loose heat by using the blower with the wood stove? Would a house fan make more sense?
Cleaning the stove or the pipe? I can't find the original comment for context, just the reply above me. Anyway...the stove isn't that hard, no ash pan but I don't think thats much of a deal breaker. In use, push the good coals to the side and get the ashes on that side out, then move the coals to the cleaned out side and get those ashes. The once a year big clean up-scoop out as much ash as you can, then remove the bricks, bottom first, then sides then top. Wire brush everything you can reach (and get dirty), then put everything back, lol. Stack probably depends on setup-ours is a straight run, so easy enough from below or above. Biggest pita is getting the top bricks and the braces they sit on in and out around the tubes, but that's not really that difficult.
I can't find the video I took of the rattle. I'll do it again come burn season I guess. We are no where near a stove shop, so it's like pulling chicken teeth to get someone out to listen to it when it's running, since obviously they aren't going to make any $$ on the deal (or maybe it's because the two "local" shops are owned by the same person and are words I can't post on a family friendly forum-which is another good possibility). Can't just bring it in, and it's usually not too bad when it first gets going so it's not as easy as holding a lighter to the snap disc to test it. We use the blower to help move the heat down a narrow hallway to the other half of the house. Personally I'd rather shut the dang thing off than listen to it...even typing this I can hear it in my head...that droning rattle...ugh.
I was referring to cleaning the pipe. Nothing to remove just pull the handle and let the Sooteater crawl its way up.
EDIT: I do remove the door![]()
But, moving air around with a fan is still a must if you are trying to heat the whole house.
We remove all of it to get to the buildup behind/under the bricks, etc. I covered the bottom (floor?) of the stove with ash and junk from all the nooks and crannies yesterday.
Coming from a one no furnace guy to another, I can agree with that! But I prefer to move cold air into the stove room, it's a more even temperature throughout the house.Depends on the size of the house, lol.
It's easier to move cold air than warm air. The best success seems to be from putting a small fan on the floor at the peripheral rooms and blow the cold air out. Warm air will flow in above it.Coming from a one no furnace guy to another, I can agree with that! But I prefer to move cold air into the stove room, it's a more even temperature throughout the house.
