Hey Maple,
That was what I was thinking when I first read Sparky's an JohnDolz's posts to the effect that ODR gives longer run time from storage. But I got to thinking about it and I believe there may be some second order effects which are not at all obvious. I'll throw out a couple of theoreticals which support the ability to run longer from storage when mixing down the tank supply with ODR:
- While I agree 100% that the energy in water is a fixed and calculate-able number, it's the available energy to the supply system which we are trying to figure out. Themo-heads would call this Exergy, and it is most definitely not equal to the energy in the tank. The Biomass Training sticky has some discussion on this.
- On Exergy, it seems to me that mixing down the tank actually increases the available energy in the tank. The reason why is the flow through the tank supply/return ports is lower using ODR than with a straight supply from the tank to the system plumbing. The reason why is system flow is made up of system return flow and supply from the tank. As we are turning over the tank less, stratification is promoted, Exergy is higher.
- Loss in system piping is less as the heat loss from system supply piping is proportional to some delta-T. Now, you can argue that all system piping loss is inside the building envelope, and there is some merit to that. It all depends on the system piping. If that piping is inside conditioned space, then, yes, this is the case. As soon as you put a supply pipe in a wall, that pipe looses heat both to the outside and inside the building envelope. It gets complicated.
- The last and quite hard to quantify effect might be that the heat emitters work more efficiently with constant flow. No experience here, but obviusly if the emitters are more efficient, then the Exergy of the system increases.
I'm planning my system to have storage in an outside building. Mixing down system supply in that building before shoving it over to the house in underground pex will certainly lower the system piping loss.
On running with a lower supply temp at the end of the storage interval, I am truly stumped. Maybe I need to get my "I violate the laws of physics" card punched?
Everything in this post is strictly theoretical and as always, your mileage may vary...
